[Qgis-user] QGIS, Problem showing the outputs
Alexander Bruy
alexander.bruy at gmail.com
Sun Apr 19 05:54:52 PDT 2020
Hi Hamzeh,
you should contact plugin authors with this issue.
нд, 19 квіт. 2020 о 15:51 Hamzeh Mohammadigheymasi <hamzeh at ubi.pt> пише:
> Hi
> I am running 3.12.1-București on an Ubuntu 18.04. The goal is to run OpenQuake IRMT plugin. It runs well and gives the outputs, however, I have problems loading the results; more precisely, when I load the outputs, I receive the following error:
> ValueError: 'Spectral' is not in list
> Traceback (most recent call last):
> File "/home/shazam/.local/share/QGIS/QGIS3/profiles/default/python/plugins/svir/dialogs/load_gmf_data_as_layer_dialog.py", line 165, in accept
> super().accept()
> File "/home/shazam/.local/share/QGIS/QGIS3/profiles/default/python/plugins/svir/dialogs/load_output_as_layer_dialog.py", line 875, in accept
> self.load_from_npz()
> File "/home/shazam/.local/share/QGIS/QGIS3/profiles/default/python/plugins/svir/dialogs/load_gmf_data_as_layer_dialog.py", line 174, in load_from_npz
> self.iface, self.output_type)
> File "/home/shazam/.local/share/QGIS/QGIS3/profiles/default/python/plugins/svir/dialogs/load_output_as_layer_dialog.py", line 581, in style_maps
> ramp_type_idx = default_color_ramp_names.index('Spectral')
> Please help me to solve the problem.
> Best Regards,
> Hamzeh
> Qgis-user mailing list
Alexander Bruy
