[Qgis-user] Options when loading layers into PostGIS with DBManager
Paolo Cavallini
cavallini at faunalia.it
Mon Apr 20 00:16:19 PDT 2020
Hi Michael,
it should "just work" with all the defaults, as you mention. Exceptions
are the id issue you noticed and the SINGLE/MULTI option: usually you
want SINGLE for points.
Cheers.
Il 19/04/20 17:05, Michael Dufty ha scritto:
> Answering my own question again.
> It does look like leaving everything alone works pretty well.
> Primary key unchecked results in a primary key being set up with the id
> column as shown in grey. This caused a problem when the layer had a
> pre-existing non-unique id column. Works fine if the existing id column
> has unique values, or does not exist.
> Leaving the geometry column unticked seems to create a geom column (as
> shown in grey).
> If a spatial index is needed and wasn’t ticked, a warning will show in
> db manager afterwards and it is easy to create one from there.
> Just needs the documentation update to say not to worry about it. A bit
> like the lack of documentation on how to upgrade an existing install.
> It doesn’t seem to matter what you do, but you can waste a lot of time
> trying to look it up if too cautious.
> *Michael Dufty*
> *Senior Environmental Engineer*
> *MBS ENVIRONMENTAL**
> *4 Cook Street, West Perth WA 6005
> t: +61 8 9226-3166
> f: +61 8 9226-3177
> e: mdufty at mbsenvironmental.com.au <mailto:mdufty at mbsenvironmental.com.au>
> w: www.mbsenvironmental.com.au
> <blocked::http://www.mbsenvironmental.com.au/>
> Disclaimer:
> The information contained in this message is intended for those to whom
> it is addressed. It may contain confidential or privileged information
> and if you are not the intended recipient, you must not copy, distribute
> or take any action in reliance on it. If you received this message in
> error please destroy it and reply to the sender immediately or contact
> Martinick Bosch Sell Pty Ltd. on +61 8 9226 3166 immediately. All care
> has been taken to ensure that this message and any attachments are virus
> free; we do not accept responsibility for any virus infections caused by
> receipt of this message//
> *From:*Michael Dufty <MDufty at mbsenvironmental.com.au>
> *Sent:* Sunday, 19 April 2020 4:43 PM
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] Options when loading layers into PostGIS with
> DBManager
> Hi,
> I am trying out saving data in PostGIS, and have got stuck on the upload
> “import layer/file” dialog in DB Manager.
> Can anyone recommend a good reference on what options should be selected?
> It seems to fall into a gap between PostGIS documentation and QGIS
> documentation and I can’t find any information on what should be
> selected in what circumstances.
> In particular
> Primary key – should this be ticked and the existing id field selected?
> What happens if it is left unticked?
> Geometry column – is this needed? Objects still seem to have geometry if
> it is left out.
> Create spatial index – this sounds like a good idea, but the one youtube
> tutorial I found (Klas Karlson) he left it unticked and said the layer
> already had everything. Is it needed for some source formats and not
> others eg shapefile vs geopackage?
> Convert field names to lower case doesn’t sound very useful, but I
> presume it is there for a reason, does anyone know the circumstances
> that would be needed?
> Cheers,
> *Michael Dufty*
> t: +61 8 9226-3166
> f: +61 8 9226-3177
> Disclaimer:
> Qgis-user mailing list
Paolo Cavallini - QGIS.ORG Chair
www.faunalia.eu:
training, support, development on QGIS, PostGIS and more
