[Qgis-user] [QGIS-Developer] Memory Leak / Slowdown?
Matthias
matthias at opengis.ch
Mon Apr 20 06:39:33 PDT 2020
Hi Peter,
It's possible that a part of the cleanup only happens on the next event loop run.
Questions / things to try:
- Do you really need to add them to the project or is a layer without adding it to the project good enough for your purpose?
- Can you run this in batches of ~100 (or even 1) each and then trigger the next batch on a new event loop invocation, e.g. by using QTimer.singleShot()
- The easiest thing would be calling QgsApplication.processEvents(), but be warned that using this is known for introducing instabilities, depending on the context in which it is called
Matthias
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200420/230c0781/attachment-0001.html>
