[Qgis-user] Unable to Clip Raster from WMS Source
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Apr 20 09:32:29 PDT 2020
You could try starting QGIS with command line options. I did not find the option for QGIS 3 but this probably works. https://docs.qgis.org/2.18/en/docs/user_manual/introduction/getting_started.html#command-line-options
The biggest problem is that you will probably not be able to download the entire US at the resolution you want. Most wms server will limite the size of the download. What are you trying to download exactly? Can you find the original data that does come from a wms server?
Please do a reply all so that the QGIS user groupe can profit of the conversation.
Cheers!
Nicolas Cadieux
Ça va bien aller!
> Le 20 avr. 2020 à 00:38, Michael Demeyer <Michael at demeyer.org> a écrit :
> Nicolas,
> Thanks for the reply. The problem is that the entire thing is the entire United States. So I have to clip before I can save it.
> Any idea why it is not working?
> Michael
> Sent from Mail for Windows 10
> From: Nicolas Cadieux
> Sent: Sunday, April 19, 2020 5:46 PM
> To: Michael Demeyer
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Unable to Clip Raster from WMS Source
> Hi,
> You need to export the image first. Try exporting the project as a .tiff then, you will be able to clip the new image.
> Nicolas Cadieux
> Ça va bien aller!
> Le 19 avr. 2020 à 20:01, Michael Demeyer <Michael at demeyer.org> a écrit :
> Have connected a WMS server for the NAIP Imagery data (US Department of Agriculture) to a layer in a project, which seems to function properly. I am trying to export a sub-section of the data using the Clip Raster by Extent function, also specifying the resolution at 30 x 30 meters.
> Below is the input string to GDAL that is created. I consistently (100% of the time) get an error saying “Failure: No Target Dataset Specified”
> Have tried everything I can think of. This command works fine for me on local data, but is somehow not working for this WMS source.
> Thanks!
> Michael
> QGIS version: 3.12.1-București
> QGIS code revision: 121cc00ff0
> Qt version: 5.11.2
> GDAL version: 3.0.4
> GEOS version: 3.8.1-CAPI-1.13.3
> PROJ version: Rel. 6.3.1, February 10th, 2020
> Processing algorithm…
> Algorithm 'Clip raster by extent' starting…
> Input parameters:
> { 'DATA_TYPE' : 0, 'EXTRA' : '', 'INPUT' : 'contextualWMSLegend=0&crs=EPSG:4326&dpiMode=7&featureCount=10&format=image/jpeg&layers=0&styles&url=https://services.nationalmap.gov/arcgis/services/USGSNAIPImagery/ImageServer/WMSServer', 'NODATA' : None, 'OPTIONS' : '', 'OUTPUT' : 'E:/Flying/Landscape Building/Imagery Test/jpeg test.bil', 'PROJWIN' : '415804, 761404, 3987838, 4379518' }
> GDAL command:
> gdal_translate -projwin 415804.0 4379518.0 761404.0 3987838.0 -of EHdr contextualWMSLegend=0&crs=EPSG:4326&dpiMode=7&featureCount=10&format=image/jpeg&layers=0&styles&url=https://services.nationalmap.gov/arcgis/services/USGSNAIPImagery/ImageServer/WMSServer "E:/Flying/Landscape Building/Imagery Test/jpeg test.bil"
> GDAL command output:
> FAILURE: No target dataset specified.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200420/36f02225/attachment-0001.html>
