[Qgis-user] 2019 USGS 7.5min topo sheets
    Mike Flannigan
    mikeflan at att.net
    Tue Apr 21 11:22:00 PDT 2020
Much to my surprise I think you are correct.
QGIS can open a TIF file (and a zipped TIF file),
but I can't get a GeoPDF to open in QGIS.  If I
convert the GeoPDF to a TIF with GDAL, it still
will not open and gives error "Missing Codec".
Very surprising.  I know from past experience that
Global Mapper v6.04 will view TIF files that have
been converted from GeoPDF via GDAL.
Mike
On 4/20/20 5:00 PM, qgis-user-request at lists.osgeo.org wrote:
> It sounds like you downloaded a new USGS product format called the GeoPDF. The ".pdf" suffix is the big clue. I don't know if QGIS 3.2.3 can read those files. I would try downloading the map in a different format. I don't know what site you are using, but the USGS TopoView site (https://ngmdb.usgs.gov/topoview/) has the maps available as JPEG, KMZ, GeoTIFF, and GeoPDF. I would recommend the GeoTIFF format as all versions of QGIS support that.
> Best,
> 	++Eric Fielding
