[Qgis-user] documentation v 3.10 - PDF ?
Alexandre Neto
senhor.neto at gmail.com
Thu Apr 23 14:09:00 PDT 2020
Hello Karsten,
The documentation team decided to drop the PDF creation, because It was a
big overhead in the all process.
The plan is to provide the HTML version in a zip package instead, but we
were not able to tackle that yet. We think the HTML package will replace
the PDF functionality, while providing another advantage. Having a local
copy of the HTML, one can set QGIS to use it as an alternative to online
documentation. That way, if you press a help button while offline, it will
redirect to you local copy.
Thanks,
Alexandre Neto
A quinta, 23/04/2020, 19:26, karsten <karsten at terragis.net> escreveu:
> Dear all,
> I have looked at the nice new documentation for QGIS v. 3.10 online (HTML)
> but wanted to find the PDF versions which unfortunately I could not locate
> so far (last ones I found are 3.4 ).
> Can someone point me to the doc PDFs ?
> or are there none available (unless I would install all the docs source
> code and try to compile them myself as PDF ) ?
> Thanks + Cheers
> Karsten
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200423/9112751e/attachment.html>
