[Qgis-user] PyQGIS to add PostGIS raster layer?
Yann Voté
ygversil at lilo.org
Thu Apr 30 00:59:04 PDT 2020
Sorry, I read too fast. Didn't see it was about raster layers.
But here is a clue : load the raster layer manually, then look at the
tooltip appearing when you hover the cursor on the layer. It will
contain the connection string.
Le 30/04/2020 à 09:45, Yann Voté a écrit :
> Hi,
> Something like this should do.
> pg_layer = QgsVectorLayer(
> "host=db.priv.example.org port=5432 authcfg=expauth srid=4326 "
> "dbname=exampledb table='schema'.'table_name' (geometry) "
> "type=MULTIPOLYGON sql=",
> baseName='table_name',
> providerLib='postgres',
> QgsProject.instance().addMapLayer(pg_layer)
> Of course, adapt with your values. In particular, authcfg is the 7-chars
> identifier of the auth configuration that contains your login and
> password (or cert) to authenticate to PostgreSQL.
> See https://qgis.org/pyqgis/master/core/QgsVectorLayer.html
> See also
> https://qgis.org/pyqgis/master/core/QgsDataSourceUri.html#qgis.core.QgsDataSourceUri
> for more options to build database connection strings.
> Regards.
> Yann
> Le 30/04/2020 à 00:24, thayeray a écrit :
>> Is it possible to add a PostGIS raster layer to a project using PyQGIS?
>> The PyQGIS Developer Cookbook mentions adding rasters from files,
>> geopackages and WCS services.
>> If I try using a QgsDataSourceUri by feeding it a raster column
>> instead of a
>> geometry column, the PostGIS error that is generated shows that is not
>> going
>> to work because raster is not a geometry:
>> WARNING Erroneous query: SELECT 0, array_agg(DISTINCT
>> st_srid("rast")::text || ':' || UPPER(geometrytype("rast"))) FROM
>> "public"."indicators__g_economic_rebal_r_62ft" returned 7 [ERROR:
>> function
>> geometrytype(raster) does not exist
>> Any ideas of what I can do? Do I just have to give up on PostGIS
>> rasters and
>> just turn it into WCS on the server?
>> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
