[Qgis-user] PDF output - file size
Ryan Brook (Perth)
Ryan.Brook at advisian.com
Sat Aug 1 09:17:27 PDT 2020
Hi Tony,
Consider using multiply blending mode for your map in the rendering menu of item properties.
This will lose transparency but reduce file size (could be an order of magnitude decrease if you have many raster layers loaded).
[cid:image001.png at 01D66861.B931BF90]
Not sure if the simplify geometries option will help you:
[cid:image002.png at 01D66862.4BC39180]
Regards,
Ryan
-----Original Message-----
Sent: Friday, 31 July 2020 7:26 AM
To: Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] PDF output - file size
On Fri, 31 Jul 2020 at 09:20, Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz<mailto:tony at farmmaps.nz>> wrote:
> Hi All
> Hope all is well. I’m really liking QGIS 3.14!!
> I have a question re the file size of PDF outputs. Since upgrading to 3.14, the file size of PDF outputs seems to have grown by a substantial amount. If I have SVG or font marker fills, even more so. An A3 map, typically was 5mb or so, now it is outputting at close to 30mb. Id then normally use Acrobat to compress and get it down a bit without losing any discernable quality (but retain geo info), but even then it's still over 20mb.
Previously svg or font marker fills were exported as raster patterns, which resulted in a loss of quality when the PDFs were printed or zoomed in to. Since 3.14 we now output marker fills using vector artwork wherever possible, in order to avoid this loss of quality.
> How do others deal with this issue? Is there anywhere that I can have some control over the DPI of the output etc, much like the old days when we hade Acrobat installed as a stand-alone printer driver?
There's no option for this in current versions, but it's worth filing a feature request!
Nyall
*** Advisian Notice *** "This email is confidential. If you are not the intended recipient, you must not disclose or use the information contained in it. If you have received this email in error, please notify us immediately by return email and delete the email and any attachments. Any personal views or opinions expressed by the writer may not necessarily reflect the views or opinions of any company in the WorleyParsons Group of Companies. How we use your personal data: http://www.advisian.com/en-us/who-we-are/privacy-policy /SPAN>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200801/224ff04d/attachment.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200801/224ff04d/attachment.png>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200801/224ff04d/attachment-0001.png>
