[Qgis-user] Show image time with Temporal Controller
Frank Sokolic
sokolic at worldonline.co.za
Mon Aug 3 09:00:10 PDT 2020
Thanks for the tips everyone. I've added an expression to the Decoration
Title that shows the date/time for each image in the format "2020-08-03
14:00 UTC". This is the expression:
[% format_date((@animation_start_time +
make_interval(hours:=(hour(@frame_duration) *
@frame_number))),'yyyy-MM-dd HH:mm')%] UTC
There's probably a more efficient way of doing this but it works for me.
Frank.
On 2020/08/03 14:04, DelazJ wrote:
> Hi Frank
> Probably related:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-How-to-get-animation-datetime-td5442097.html
> Regards,
> Harrissou
> Le lun. 3 août 2020 à 13:58, Frank Sokolic <sokolic at worldonline.co.za
> <mailto:sokolic at worldonline.co.za>> a écrit :
> Hi Charles,
> The images are being loaded from a WMS-T service and so don't have
> attributes. Is there any way of using an expression to get details
> of the current image from the temporal controller or perhaps get
> the WMS-T parameters being sent for each image in the sequence?
> Frank.
> On 2020/08/03 13:14, Charles Dixon-Paver wrote:
>> Hi Frank, I haven't tested this, but wouldn't you be able to get
>> this from the layer attributes that are configured in the
>> temporal controller settings?
>> On Mon, 3 Aug 2020 at 13:07, Frank Sokolic
>> <sokolic at worldonline.co.za <mailto:sokolic at worldonline.co.za>> wrote:
>> Hi,
>> I'm using the QGIS 3.14 Temporal Controller to step through a
>> series of
>> satellite images in 15 minute intervals and would like to
>> show the
>> date/time of each image as it appears on the map. There are
>> variables
>> for the start and end animation times (animation_start_time,
>> animation_end_time) that I can use in my expression but can't
>> see
>> anything for the data/time of the current image. Does anyone
>> know if
>> such a variable exists?
>> Thanks, Frank.
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200803/775edd31/attachment.html>
