[Qgis-user] Migrating legacy QGIS instance
Charles Dixon-Paver
charles at kartoza.com
Tue Aug 11 03:45:04 PDT 2020
Easiest way for me is to use the GDAL ogr2ogr
<https://gdal.org/programs/ogr2ogr.html> command using a bash script or cmd
batch to traverse your directories (depending on how you installed QGIS
this should be on your path). I don't know what environment you're running
though.
You can either stick multiple shps into a single gpkg or create one per
feature as you prefer. ogr2ogr can also push shp files directly into
PostGIS. When you want to consolidate or migrate data (between gpkgs or
from gpkg to PostGIS) you can simply select the feature layers you want and
use drag and drop from the QGIS 3 Browser panel to copy multiple features
to a target location.
Others might have different approaches though.
Regards
On Tue, 11 Aug 2020 at 12:24, Walt Ludwick <walt at valedalama.net> wrote:
> I've inherited a legacy GIS, built up over some years in versions 2.x,
> that i'm now responsible to maintain. Being an almost complete n00b (did
> take a short course in QGIS a good few years ago, but still..), i could
> really use some advice about migration.
> i've created a new QGIS instance in version 3.14, into which i am trying
> to bring all useful content from our old system: oodles of shapefiles,
> essentially, plus all those other files (each .shp file appears to bring
> with it a set of.shx, .dbf, .prj, qpj files, plus a .cpg file for each
> layer, it seems). This is a significant dataset- 14gb, >1000 files -and
> that is just base data, not counting Projects built on this data or Layouts
> used for presenting these projects in various ways. Some of this is cruft
> that i can happily do without, but still: i've got a lot of porting-over
> to do, without a clear idea of how best to do it.
> The one thing i'm clear about is: i want it all in a non-proprietary
> database (i.e. no more mess of .shp and related files) that is above all
> quick & easy to navigate & manage. It is a single-user system at this
> point, but i do aim to open it up to colleagues (off-LAN, i.e. via
> Internet) as soon as i've developed simple apps for them to use. No idea
> how long it'll take me to get there, so...
> Big question at this point is: What should be the new storage format for
> all this data? Having read a few related opinions on StackOverflow, i get
> the sense that GeoPackage will probably make for easiest migration (per this
> encouraging article
> <https://medium.com/@GispoFinland/learn-spatial-sql-and-master-geopackage-with-qgis-3-16b1e17f0291>,
> it's a simple matter of drag&drop -simple if you have just a few, i guess!
> [1]), and can easily support my needs in the short term, but then i wonder:
> How will i manage migration to PostGIS when i eventually put this system
> online with different users/ roles enabled?
> [1] Given that i need to pull in some hundreds of .shp files that are
> stored in a tree of many folders & subfolders, i also wonder: is there a
> simple way that i can ask QGIS to traverse a certain directory, pull in all
> the .shp files -each as its own .gpkg layer, i suppose?
> Any advice about managing this migration would be much appreciated!
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200811/a8900d27/attachment.html>
