[Qgis-user] Migrating legacy QGIS instance
Walt Ludwick
walt at valedalama.net
Tue Aug 11 05:36:34 PDT 2020
This is great to hear, Phil & Charles; from what you both say, i gather
that migration to PostGIS will be easy enough, when the time comes for
that... And so i can standardize my new installation on GeoPackage without
concern that i may regret this later. Thanks for instructing me about
these options!
On Tue, Aug 11, 2020 at 12:26 PM Philip Barlow <
philipb at pembrokeshirecoast.org.uk> wrote:
> OGR is a great option, if you wanted a GUI you could also do it with the
> “export to PostgreSQL” processing tool in batch processing mode (right
> click). Select all the layers and then you can auto fill the fields for
> primary key, geometry column etc.
> Phil
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of *Charles
> Dixon-Paver
> *Sent:* 11 August 2020 11:45
> *To:* Walt Ludwick <walt at valedalama.net>
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Migrating legacy QGIS instance
> Easiest way for me is to use the GDAL ogr2ogr
> <https://gdal.org/programs/ogr2ogr.html> command using a bash script or
> cmd batch to traverse your directories (depending on how you installed QGIS
> this should be on your path). I don't know what environment you're running
> though.
> You can either stick multiple shps into a single gpkg or create one per
> feature as you prefer. ogr2ogr can also push shp files directly into
> PostGIS. When you want to consolidate or migrate data (between gpkgs or
> from gpkg to PostGIS) you can simply select the feature layers you want and
> use drag and drop from the QGIS 3 Browser panel to copy multiple features
> to a target location.
> Others might have different approaches though.
> Regards
> On Tue, 11 Aug 2020 at 12:24, Walt Ludwick <walt at valedalama.net> wrote:
> I've inherited a legacy GIS, built up over some years in versions 2.x,
> that i'm now responsible to maintain. Being an almost complete n00b (did
> take a short course in QGIS a good few years ago, but still..), i could
> really use some advice about migration.
> i've created a new QGIS instance in version 3.14, into which i am trying
> to bring all useful content from our old system: oodles of shapefiles,
> essentially, plus all those other files (each .shp file appears to bring
> with it a set of.shx, .dbf, .prj, qpj files, plus a .cpg file for each
> layer, it seems). This is a significant dataset- 14gb, >1000 files -and
> that is just base data, not counting Projects built on this data or Layouts
> used for presenting these projects in various ways. Some of this is cruft
> that i can happily do without, but still: i've got a lot of porting-over
> to do, without a clear idea of how best to do it.
> The one thing i'm clear about is: i want it all in a non-proprietary
> database (i.e. no more mess of .shp and related files) that is above all
> quick & easy to navigate & manage. It is a single-user system at this
> point, but i do aim to open it up to colleagues (off-LAN, i.e. via
> Internet) as soon as i've developed simple apps for them to use. No idea
> how long it'll take me to get there, so...
> Big question at this point is: What should be the new storage format for
> all this data? Having read a few related opinions on StackOverflow, i get
> the sense that GeoPackage will probably make for easiest migration (per this
> encouraging article
> <https://medium.com/@GispoFinland/learn-spatial-sql-and-master-geopackage-with-qgis-3-16b1e17f0291>,
> it's a simple matter of drag&drop -simple if you have just a few, i guess!
> [1]), and can easily support my needs in the short term, but then i wonder:
> How will i manage migration to PostGIS when i eventually put this system
> online with different users/ roles enabled?
> [1] Given that i need to pull in some hundreds of .shp files that are
> stored in a tree of many folders & subfolders, i also wonder: is there a
> simple way that i can ask QGIS to traverse a certain directory, pull in all
> the .shp files -each as its own .gpkg layer, i suppose?
> Any advice about managing this migration would be much appreciated!
> Qgis-user mailing list
> Mae'r Awdurdod yn hapus i gyfathrebu yn Gymraeg neu yn Saesneg
> The Authority is happy to communicate in Welsh or English
> Website www.pembrokeshirecoast.wales
> Follow us on Twitter <http://twitter.com/PembsCoast>
> Join us on Facebook
> <http://www.facebook.com/group.php?gid=26330984774&ref=ts>
> Watch us on Youtube
> <http://www.youtube.com/user/pcnpa2008#p/u/0/Tw8Udou0p5k>
> Look at us on Flickr <http://www.flickr.com/photos/pembrokeshirecoast/>
> This email and any attached files should only be read by those persons to
> whom
> they are addressed and be used by them only for their intended purpose.
> If you are not the intended recipient please destroy all copies and inform
> the
> sender by return email.
> Please note that the contents of this email may be subject to public
> disclosure
> under the Freedom of Information Act 2000 and therefore the
> confidentiality of
> this message and any reply cannot be guaranteed.
> Click here <https://www.pembrokeshirecoast.wales/privacy/> to view PCNPA
> Privacy Notice – Keeping your Information Safe
> For further information on the PCNPA please visit our website at
> Please consider the environment before printing this email.
> Dim ond y personau hynny yr anfonwyd yr e-bost hwn atynt ac unrhyw
> ffeiliau sydd
> ynghlwm ddylid eu darllen, a dim ond hwy ddylid eu defnyddio at y diben y
> bwriadwyd hwy.
> Os nad y chi yw'r person y bwriadwyd eu derbyn a fyddech gystal â
> dinistrio pob copi a rhoi
> gwybod i'r anfonwr gyda throad yr e-bost.
> Noder os gwelwch yn dda y gall cynnwys yr e-bost hwn orfod cael ei
> ddatgelu i'r cyhoedd o
> dan Deddf Rhyddid Gwybodaeth 2000 ac felly ni ellir gwarantu cyfrinachedd
> y neges hon
> nac unrhyw ateb.
> Cliciwch yma <https://www.arfordirpenfro.cymru/preifatrwydd/> i weld
> Hysbysiad Preifatrwydd APCAP - Cadw eich Gwybodaeth yn Ddiogel
> Am ragor o wybodaeth am APCAP ymwelwch â'n gwefan ar
> Ystyrier yr amgylchedd cyn argraffu'r e-bost hwn os gwelwch yn dda.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200811/3d930f6e/attachment.html>
