[Qgis-user] Label overlapping between layers
Rossin Pietro
pietro.rossin at arpa.fvg.it
Tue Aug 11 07:52:31 PDT 2020
Hello everybody
I'm facing a problem in Qgis 3.14
I have two polygon layers each one with its own labels.
A layer is on top of the other
I would like that the label of the bottom one wil not overlap the top one geometry.
Is there any way to achieve this?
I played with label weight but I didn't get success
Thanks
Pietro
AVVISO DI RISERVATEZZA Informazioni riservate possono essere contenute nel messaggio o nei suoi allegati. Se non siete i destinatari indicati nel messaggio, o responsabili per la sua consegna alla persona, o se avete ricevuto il messaggio per errore, siete pregati di non trascriverlo, copiarlo o inviarlo ad alcuno. In tal caso vi invitiamo a cancellare il messaggio ed i suoi allegati. Grazie.
CONFIDENTIALITY NOTICE Confidential information may be contained in this message or in its attachments. If you are not the addressee indicated in this message, or responsible for message delivering to that person, or if you have received this message in error, you may not transcribe, copy or deliver this message to anyone. In that case, you should delete this message and its attachments. Thank you.
