[Qgis-user] Migrating legacy QGIS instance
Walt Ludwick walt at valedalama.net
Tue Aug 11 10:38:27 PDT 2020
Thanks for the tip, Bobb; i had a look at https://www.geomoose.org/ and it
sounds good... But not for MacOS users, alas, unless i am missing
something.  If there be any such thing available for Mac tho (?), i would
love to give it a try!
On Tue, Aug 11, 2020 at 2:13 PM Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
> *Depending on your end goal, you might be more suited to leaving things as
> they are and using  some sort of content explorer to organize the existing
> data.  Then worry about migrating to different formats as needed.*
> *We’ve been using GeoMoose for this purpose.  It can connect to just about
> any data source on the back end, such as SHP, Postgres, and GeoPackage to
> name a few, but also can connect to proprietary services as well.  Because
> it can use Mapserver as a display engine and data query tool, it lends
> itself to online exploration of the data without the need for a full blown
> GIS tool.  This allows for wide spread use by non-GIS pros.  The datasets
> can still be managed by you with QGIS and/or in Postgres/postgis, or
> whatever you prefer for that purpose.  The Mapserver setup allow for
> connecting to just about any type of service behind the scenes, and with
> the right configuration, you can also enable each dataset in the GeoMoose
> catalog as a WMS/WFS data source, thee standard for open data format access
> and publishing.*
> *Bobb*
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> * On Behalf Of *Walt
> Ludwick
> *Sent:* Tuesday, August 11, 2020 7:45 AM
> *To:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Migrating legacy QGIS instance
> *Think Before You Click: *This email originated *outside *our
> organization.
> I'm on MacOS -and not so very comfortable with command line scripting- so
> it looks like i might have to go the drag&drop way to import these .shp
> files. Will take some time, but at least that way i can be sure about what
> i've put where, and in what form.
> But i do wonder about the (a) "stick multiple shps into a single gpkg" OR
> (b) "create one per feature" decision, since i'm not experienced enough to
> have a clear preference about this.  Can you say anything about pros & cons
> of going one way vs the other?
> On Tue, Aug 11, 2020 at 11:45 AM Charles Dixon-Paver <charles at kartoza.com>
> wrote:
> Easiest way for me is to use the GDAL ogr2ogr
> <https://gdal.org/programs/ogr2ogr.html> command using a bash script or
> cmd batch to traverse your directories (depending on how you installed QGIS
> this should be on your path). I don't know what environment you're running
> though.
> You can either stick multiple shps into a single gpkg or create one per
> feature as you prefer. ogr2ogr can also push shp files directly into
> PostGIS. When you want to consolidate or migrate data (between gpkgs or
> from gpkg to PostGIS) you can simply select the feature layers you want and
> use drag and drop from the QGIS 3 Browser panel to copy multiple features
> to a target location.
> Others might have different approaches though.
> Regards
> On Tue, 11 Aug 2020 at 12:24, Walt Ludwick <walt at valedalama.net> wrote:
> I've inherited a legacy GIS, built up over some years in versions 2.x,
> that i'm now responsible to maintain.  Being an almost complete n00b (did
> take a short course in QGIS a good few years ago, but still..), i could
> really use some advice about migration.
> i've created a new QGIS instance in version 3.14, into which i am trying
> to bring all useful content from our old system: oodles of shapefiles,
> essentially, plus all those other files (each .shp file appears to bring
> with it a set of.shx, .dbf, .prj, qpj  files, plus a .cpg file for each
> layer, it seems).  This is a significant dataset- 14gb, >1000 files -and
> that is just base data, not counting Projects built on this data or Layouts
> used for presenting these projects in various ways. Some of this is cruft
> that i can happily do without, but still:  i've got a lot of porting-over
> to do, without a clear idea of how best to do it.
> The one thing i'm clear about is: i want it all in a non-proprietary
> database (i.e. no more mess of .shp and related files) that is above all
> quick & easy to navigate & manage. It is a single-user system at this
> point, but i do aim to open it up to colleagues (off-LAN, i.e. via
> Internet) as soon as i've developed simple apps for them to use.  No idea
> how long it'll take me to get there, so...
> Big question at this point is: What should be the new storage format for
> all this data?  Having read a few related opinions on StackOverflow, i get
> the sense that GeoPackage will probably make for easiest migration (per this
> encouraging article
> <https://medium.com/@GispoFinland/learn-spatial-sql-and-master-geopackage-with-qgis-3-16b1e17f0291>,
> it's a simple matter of drag&drop -simple if you have just a few, i guess!
> [1]), and can easily support my needs in the short term, but then i wonder:
> How will i manage migration to PostGIS when i eventually put  this system
> online with different users/ roles enabled?
> [1] Given that i need to pull in some hundreds of .shp files that are
> stored in a tree of many folders & subfolders, i also wonder: is there a
> simple way that i can ask QGIS to traverse a certain directory, pull in all
> the .shp files -each as its own .gpkg layer, i suppose?
> Any advice about managing this migration would be much appreciated!
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200811/93dbcd73/attachment.html>
