[Qgis-user] R: Qgis-user Digest, Vol 174, Issue 15
Rossin Pietro
pietro.rossin at arpa.fvg.it
Wed Aug 12 23:42:40 PDT 2020
Thank you Christine
No I didn't.
I think this will not work for my purpouse.
I am making pdf maps trough atlas function.
There bare two layers whose labels are in conflict
The atlas feature layer on the top, who has the label priority, and a second layer underneath the atlas layer.
I want the labels of the bottom layer to be placed external to the surface of each atlas feature (top layer).
Each bottom layer feature may contain many top layer features so If I move a bottom layer label with the label toolbar I think that the moved label will remain in its place and will not follow the atlas representation.
So I need some way to authomatically force the bottom layer labels to remain outside the atlas feature surfaces.
Did I explain myself?
Pietro
Message: 2
Date: Tue, 11 Aug 2020 13:54:23 -0700 (MST)
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Label overlapping between layers
Message-ID: <1597179263286-0.post at n6.nabble.com>
Content-Type: text/plain; charset=us-ascii
Good evening Pietro,
did you already consider to apply the functions of the label toolbar ?
With the tools of the label toolbar you may rearrange the automatic positioning of the label (e.g. move, rotate).
Regards, Christine
AVVISO DI RISERVATEZZA Informazioni riservate possono essere contenute nel messaggio o nei suoi allegati. Se non siete i destinatari indicati nel messaggio, o responsabili per la sua consegna alla persona, o se avete ricevuto il messaggio per errore, siete pregati di non trascriverlo, copiarlo o inviarlo ad alcuno. In tal caso vi invitiamo a cancellare il messaggio ed i suoi allegati. Grazie.
CONFIDENTIALITY NOTICE Confidential information may be contained in this message or in its attachments. If you are not the addressee indicated in this message, or responsible for message delivering to that person, or if you have received this message in error, you may not transcribe, copy or deliver this message to anyone. In that case, you should delete this message and its attachments. Thank you.
