[Qgis-user] Adding layer slows down QGIS dramatically after adding a layer
Peter Cornelissen
peter at cornelissen.org.uk
Thu Aug 13 16:19:23 PDT 2020
Hi Richard
Thanks for the suggestion. They are plain filters and I tried indexing
every table, but unfortunately it has made no noticeable difference.
Regards, Peter
On Thu, 13 Aug 2020 at 15:35, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 8/13/20 3:57 PM, Peter Cornelissen wrote:
> > Hi
> > I am using a Geopackage with about 15 tables (a mixture of lines,
> polygons and points), but each of these tables are
> > used 40 or 50 times with filters as many of the elements are used on
> multiple layers.
> > However, I am now finding that as soon as I add a new layer QGIS slows
> down
> > and it is taking 60 seconds or more to do almost any action that involves
> > redrawing (zoom in/out/ pan etc) or even moving a layer within the layers
> > panel. If I save the project, close down QGIS and restart, it is fine
> again
> > until the next time.
> > Any suggestions?
> > Thanks, Peter
> Looking at the attributes which are used in the filters, add 'indexes' too
> the tables in the Geopackage?
> In QGIS you can do that by creating a connection to the gpkg with DataBase
> Manager and then:
> 'edit table' > tab indexes, > add index
> A geopackage is a sqlite database, so if you have some sql-client
> (DB-manager, DB-browser) you can fire the create index query there:
> CREATE INDEX "foo_index" ON "mygeopackage" ("foo_column")
> Note that these are plain indexes, no spatial ones.
> IF your filters are spatial filters, then off course you need spatial
> indexes.
> HTH
> Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200814/d58fa10e/attachment.html>
