[Qgis-user] Null Values
Charles Dixon-Paver
charles at kartoza.com
Sun Aug 16 02:26:10 PDT 2020
You could also pull individual values out of the array, e.g.
array_get(generate_series(10,20,1), at row_number-1)
On Sun, 16 Aug 2020 at 09:45, Alexandre Neto <senhor.neto at gmail.com> wrote:
> Hello,
> The function you are using returns an Array, which does not fit a integer
> field.
> I think you can achieve what you want by using something like:
> $id + 10
> Best regards,
> Alexandre Neto
> QGIS Support
> www.qcooperative.net
> A domingo, 16/08/2020, 03:21, krishna Ayyala <ayyalakrishna at gmail.com>
> escreveu:
>> I have created a field "ID" which is an integer. I am trying to run the
>> sql query as below. I am getting all "NULL" values in my "ID" field. Can
>> anyone help me fix this?
>> Regards.
>> [image: image.png]
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200816/51815dfa/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200816/51815dfa/attachment-0001.png>
