[Qgis-user] Displaying two or more labels(fields) in a Map
Richard McDonnell richard.mcdonnell at opw.ie
Mon Aug 17 04:12:52 PDT 2020
To add to this, you can also create a single string, with symbols like hyphens to break up the text,
For example
1.       “Attribute1”||”Attribute2”||”Attribute3” would result in Attribute1Attribute2Attribute3
2.       “Attribute1”||’_’||”Attribute2”||’_’|| “Attribute3” would result in Attribute1_Attribute2_Attribute3
3.       “Attribute1”||’ ‘||”Attribute2”||’ ‘|| “Attribute3” would result in Attribute1 Attribute2 Attribute3
4.       “Attribute1”||’ - ‘||”Attribute2”||’ - ‘|| “Attribute3” would result in Attribute1 - Attribute2 - Attribute3
Hope that helps somewhat.
Regards,
Richard
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 1 647 6543
https://www.opw.ie
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.opw.ie/en/disclaimer/
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Charles Dixon-Paver
Sent: 16 August 2020 11:56
To: jean Lukusa <lukusam at gmail.com>
Cc: Qgis Users List <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Displaying two or more labels(fields) in a Map
If I understand what you are trying to achieve correctly, you can build the required labels by concatenating values in the expression builder
[image.png]
On Sun, 16 Aug 2020 at 12:44, jean Lukusa <lukusam at gmail.com<mailto:lukusam at gmail.com>> wrote:
Hi all.
I have created two fields in my shapefile attribute table.
How Can I do to display all fields (labels) on  the Map ?
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200817/878ddbfd/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200817/878ddbfd/attachment-0001.png>
