[Qgis-user] R: Importing a raster into a Geopackage
Kirk Schmidt
kirk at nortekresources.com
Wed Dec 2 07:00:15 PST 2020
Hi all:
I ran the r.stats to get a list of each pixel value on my test data (A
small DEM) before and after conversion to a geopackage (see second image
below). The values and summary stats are identical for the two rasters
but the default legend entry has a different min and maximum value. So,
I can conclude that the data is being written correctly but the default
display parameters for the geopackage are different than a geotiff.
Kirk
On 12/1/2020 3:24 PM, Nicolas Cadieux wrote:
> Hi,
> I changed the link so you have access to more files.
> https://drive.google.com/drive/folders/1fMl9odowUFFRQFK61rTxgHeom_D8ymN6?usp=sharing
> Nicolas
> On 2020-12-01 1:58 p.m., Kirk Schmidt wrote:
>> Hi Nicolas
>> I did the same and the legend indicates a change magnitude but if I
>> subtract the geopackage raster from the original, all pixels equal zero.
>> Kirk
>> On 12/1/2020 2:36 PM, Nicolas Cadieux wrote:
>>> Hi,
>>> Tried this:
>>> gdal_translate -of GPKG -b 1
>>> C:/Users/Nicolas/Desktop/Land_cover_Corine2018.tif
>>> C:/Users/Nicolas/Desktop/test.gpkg
>>> I read 4 band and still get data modifications.
>>> Nicolas
>>> On 2020-12-01 1:28 p.m., Kirk Schmidt wrote:
>>>> Hi Nicolas:
>>>> try the -b 1 parameter. I just tried this and wrote a single band
>>>> raster from a 3 channel tiff.
>>>> Kirk
>>>> On 12/1/2020 2:03 PM, Nicolas Cadieux wrote:
>>>>> I tried
>>>>> gdal_translate -of GPKG -co "BAND_COUNT=1"
>>>>> C:/Users/Nicolas/Desktop/TEST.gpkg for the creation and
>>>>> C:\>gdal_translate -of GPKG -co "TILE_FORMAT = TIFF"
>>>>> Same problem. I wonder if we need to change the reading
>>>>> options... https://gdal.org/drivers/raster/gpkg.html
>>>>> "Opening options
>>>>> By default, the driver will expose a GeoPackage dataset as a four
>>>>> band (Red,Green, Blue,Alpha) dataset, which gives the maximum
>>>>> compatibility with the various encodings of tiles that can be
>>>>> stored. It is possible to specify an explicit number of bands with
>>>>> the BAND_COUNT opening option."
>>>>> The problem could be when QGIS Reads the file, not when it writes
>>>>> the file. I explains why we see 4 bands but not why values are
>>>>> changing. I would make a bug report or ask the question on the
>>>>> gdal dev group to get Even Rouault's attention.
>>>>> Nicolas
>>>>> On 2020-12-01 12:17 p.m., Sebastian Gutwein wrote:
>>>>>> This looks like the same issue you are having.
>>>>>> github.com/qgis/QGIS/issues/38227
>>>>>> <http://github.com/qgis/QGIS/issues/38227>
>>>>>> According to the documentation linked in the issue you need to
>>>>>> set the band count to 1 otherwise it defaults to 4.
>>>>>> <http://gdal.org/drivers/raster/gpkg.html>
>>>>>> I have not tried this to see if it works.
>>>>>> On Tue, Dec 1, 2020 at 11:52 AM Nicolas Cadieux
>>>>>> <njacadieux.gitlab at gmail.com
>>>>>> <mailto:njacadieux.gitlab at gmail.com>> wrote:
>>>>>> Hi,
>>>>>> Looking at it now. I see what you see. I will try a few things.
>>>>>> Nicolas
>>>>>> On 2020-12-01 11:42 a.m., Alberto Vavassori wrote:
>>>>>>> Hi Nicolas,
>>>>>>> thank you for the answer. I send the raster that I am
>>>>>>> interested in.
>>>>>>> Alberto
>>>>>>> *Da:*Nicolas Cadieux <njacadieux.gitlab at gmail.com>
>>>>>>> *Inviato:* martedì 1 dicembre 2020 17:40
>>>>>>> *A:* Alberto Vavassori <alberto.vavassori at polimi.it>
>>>>>>> <mailto:alberto.vavassori at polimi.it>
>>>>>>> *Cc:* qgis-user at lists.osgeo.org
>>>>>>> <mailto:qgis-user at lists.osgeo.org>
>>>>>>> *Oggetto:* Re: [Qgis-user] Importing a raster into a Geopackage
>>>>>>> Hi,
>>>>>>> Send a sample data set if you can't figure it out.
>>>>>>> Nicolas
>>>>>>> On 2020-12-01 10:35 a.m., Nicolas Cadieux wrote:
>>>>>>> Hi,
>>>>>>> Perhaps this can help:
>>>>>>> https://gdal.orgdrivers/raster/gpkg.html
>>>>>>> <https://gdal.orgdrivers/raster/gpkg.html>
>>>>>>> “Various kind of input datasets can be converted to
>>>>>>> GeoPackage raster :
>>>>>>> ·Single band grey level
>>>>>>> ·Single band with R,G,B or R,G,B,A color table
>>>>>>> ·Two bands: first band with grey level, second band with
>>>>>>> alpha channel
>>>>>>> ·Three bands: Red, Green, Blue
>>>>>>> ·Four band: Red, Green, Blue, Alpha
>>>>>>> GeoPackage rasters only support Byte data type.”
>>>>>>> My guess is that if the original raster does not
>>>>>>> correspond to one of the categories above, it will be
>>>>>>> converted to the closest format.
>>>>>>> Nicolas Cadieux
>>>>>>> https://gitlab.com/njacadieux
>>>>>>> <https://gitlab.com/njacadieux>
>>>>>>> Le 1 déc. 2020 à 09:58, Alberto Vavassori
>>>>>>> <mailto:alberto.vavassori at polimi.it> a écrit :
>>>>>>> Hello everybody. I have an issue regarding the
>>>>>>> Geopackage format. I have tried to import a
>>>>>>> singleband raster file (it represents the land
>>>>>>> cover, thus every pixel has a single integer value
>>>>>>> corresponding to the land cover class), but this
>>>>>>> operation seems to modify the raster
>>>>>>> characteristics: the raster becomes a 4-bands raster
>>>>>>> and the pixels values change accordingly (basically,
>>>>>>> the original raster is saved in the Geopackage as an
>>>>>>> RGB image). It seems to be a bug of QGIS. I have
>>>>>>> also tried to use GDAL translate through the
>>>>>>> processing toolbox of QGIS to convert the TIFF file
>>>>>>> to a Geopackage file, but the result is the same.
>>>>>>> Has anybody faced this problem? May anybody suggest
>>>>>>> a way to work this problem out?
>>>>>>> Thank you.
>>>>>>> Alberto
>>>>>>> _______________________________________________
>>>>>>> Qgis-user mailing list
>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>> <mailto:Qgis-user at lists.osgeo.org>
>>>>>>> List info:
>>>>>>> https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>>>> Unsubscribe:
>>>>>>> Nicolas Cadieux
>>>>>>> https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>>>>>> Nicolas Cadieux
>>>>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>> Unsubscribe:
>>>>> Nicolas Cadieux
>>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Kirk Schmidt, MScF, BScF, RPF
>>>> General Manager
>>>> Nortek Resource Solutions Inc.
>>>> RR # 1
>>>> Thorburn, NS
>>>> B0K 1W0
>>>> Tel (902) 922.3607
>>>> Email:kirk at nortekresources.com
>>>> Web:www.nortekresources.com
>>> Nicolas Cadieux
>> General Manager
>> RR # 1
>> Thorburn, NS
>> B0K 1W0
>> Tel (902) 922.3607
> Nicolas Cadieux
General Manager
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekresources.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201202/98a94c3b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201202/98a94c3b/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201202/98a94c3b/attachment-0003.png>
