[Qgis-user] Importing a raster into a Geopackage
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Thu Dec 3 08:56:05 PST 2020
Feature Request was made to disable JPEG lossy compression on Byte data
type when exporting raster to a geopackage. This is not technically a
bug report as this is the default mode for the driver.
https://github.com/qgis/QGIS/issues/40425
On 2020-12-01 9:56 a.m., Alberto Vavassori wrote:
> Hello everybody. I have an issue regarding the Geopackage format. I
> have tried to import a singleband raster file (it represents the land
> cover, thus every pixel has a single integer value corresponding to
> the land cover class), but this operation seems to modify the raster
> characteristics: the raster becomes a 4-bands raster and the pixels
> values change accordingly (basically, the original raster is saved in
> the Geopackage as an RGB image). It seems to be a bug of QGIS. I have
> also tried to use GDAL translate through the processing toolbox of
> QGIS to convert the TIFF file to a Geopackage file, but the result is
> the same.
> Has anybody faced this problem? May anybody suggest a way to work this
> problem out?
> Thank you.
> Alberto
> Qgis-user mailing list
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201203/014d1d12/attachment.html>
