[Qgis-user] Qgis-user Problem splitting polygons with line layer
Thayer Young thayeray at yahoo.com
Mon Dec 7 14:44:14 PST 2020
 Hi Bernd,
That sounds like you may have a topology problem, like self intersection.
Have you tried 'Vector Geometry': 'Fix Geometries' in the Processing Toolbox?In the same place there is also a 'Check validity' tool, which would find the problems for you and then you could fix them manually. The tool gives you options for different standards of validity.Another possibility is that you have mixed geometry types. You might be able to fix that with GRASS: v.type or Processing:'Vector geometry': 'Convert geometry type'
In PostGIS you would check if the imported geometry column is SELECT id FROM dwg_table WHERE NOT ST_IsSimple(geom)or: SELECT ST_GeometryType(geom) FROM dwg_table GROUP BY ST_GeometryType(geom).
-Thayer
    On Monday, December 7, 2020, 01:58:04 PM EST, qgis-user-request at lists.osgeo.org <qgis-user-request at lists.osgeo.org> wrote:
Date: Mon, 7 Dec 2020 19:57:19 +0100
From: Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
To: qgis-user <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Problem splitting polygons with line layer
Message-ID: <82a7c751-29c2-9906-25e6-9038979865ef at gmx.de>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
I need to split a polygon with a line layer (representing parcel
boundaries ).
Using "Split with lines", the process always stops at 12% and there is
no progress visible. The lines are imported from a CAD dwg as a
CompoundCurveZ (never had to do with this before)
My goal is to "cut" the polygon, so I retrieve parcels of a specific
area again.
With other line layers from this dwg ist no problem spliting the
polygon, only the parcel boundaries won't work.
Does anybody have an idea what could be the cause of this problem, what
I other tools I could try or if I have to proprocess the lines
beforehand with other tools?
Hoping for enlightment (and having a deadline tomorrow)
Bernd
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201207/225f30a8/attachment.html>
