[Qgis-user] QGIS really slow with .gpkg layers
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Tue Dec 15 11:30:22 PST 2020
See below.
On 2020-12-10 5:36 p.m., Francesco Pelullo wrote:
> Il gio 10 dic 2020, 16:50 Nicolas Cadieux <njacadieux.gitlab at gmail.com
> <mailto:njacadieux.gitlab at gmail.com>> ha scritto:
>     Hi,
>     I also used txt files to load LiDAR points in QGIS because .shp
>     was not good.  This was before .gpkg came along, before I learned
>     Python or CloudCompare.   I am just starting to familiarize myself
>     with the geopackage format so i am no .gpkg expert but this is
>     what I would do or ask myself:
>     How are the files stored? Server, USB stick, hard-drive, SSD?
> They are usually stored in a SMB server, accessible via VPN because
> this Company has multiple offices. However, due to the really slowly
> data access, projects and data are moved in local SSD disk before
> access/editing.
>     Are the files in the same CRS as the project?  If not, every thing
>     may be read in cache and reprojected even before you start...
> Yes, projects and data layers are created with same CRS.
>     What happens when the files are simplified?  Try more files and
>     less layer, try more points in the same files.
> This could be easy to do, i will check on next job.
>     Try a fresh project an open the layers one by one.  Is one more
>     problematic than others?
> No, It seems to me that geopackages becames slow after some days.
> E.g., if i create a new project and new geopackages, qgis has no
> problems to open them in a decent time (one or two minutes). But after
> some hours, if i close qgis and restart it with the same project/data,
> access becames really slow (15 minutes and more).
This is probably what we need to google for then.
I Found this ???
https://gis.stackexchange.com/questions/338478/reading-geopackage-with-large-feature-classes-is-very-slow
Perhaps you should get on the QGIS dev mailing list and ask why
geopackage get progressively slower.
Cheers!
>      Enough memory?
> Win10, i5, 16GB RAM, SSD 1TB, dual screen.
>     Disable all plugins.
> Ok.
>     Caching features: in your QGIS options, you can change the amount
>     of featured that are cashed when you open a lector layer.  Try
>     cashing more feature or much less features (like 1).  What
>     happens?  If you have a max of 16000 features per layer, chances
>     are you are caching everything so everything is being loaded to
>     memory.
> Ok i will try.
>     File creation: how are the files created?  Look at the options in
>     Gdal if the files are created in QGIS.
>     https://gdal.orgdrivers/vector/gpkg.html
>     <https://gdal.orgdrivers/vector/gpkg.html> Try creating the files
>     with Gdal translate (vector menu) instead of just “export as” or
>     save as in QGIS, force extra option to force index creation.
> They are imported in qgis as CSV (are point geometries with a single
> attribute as REAL) and then exported in gpkg format.
> In export options, spatial index creation is enabled by default.
>     Do you have a spatial index build in? In theory .gpkg comes with a
>     spatial index but perhaps you can rebuild one? Or make sure you
>     build on from the start when you create the file. (See above).
> Sometime i run Vacuum from QGIS db manager. Also sometime i force a
> new spatial index creation from layer properties, but with no
> appreciable differences.
>     I remember that when I created a .gpkg in python, and used it in
>     ArcGis, the file would take a long time to open because it was
>     reading every point of the file in order just  to get the files
>     extent. Maybe that is going on?  I think you can specify the files
>     extent in the file metadata.  (I would need to check my code but I
>     don’t see my solution here. I normally post them whenI find
>     them...). https://gis.stackexchange.com/questions/374408/using-geopandas-generated-gpkg-in-arcmap
>     <https://gis.stackexchange.com/questions/374408/using-geopandas-generated-gpkg-in-arcmap>
>     Just a bunch of ideas...
> Thank you for your suggestions.
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201215/e30445e4/attachment-0001.html>
