[Qgis-user] Import mapinfo tabfile
Kirk Schmidt
kirk at nortekresources.com
Thu Dec 17 07:18:09 PST 2020
Hi Jean:
The tab file is what you need to open. The other files make up the rest
of the components of the vector file similar to a shapefile. You can
either drag and drop the tab file into and open QGIS canvas or use the
add vector layer button. If you use the later, you can select the file
type to Mapinfo and the suitable files will be displayed (*.TAB files).
Kirk Schmidt
On 12/17/2020 7:34 AM, Weijers, Jean (Kerkrade) wrote:
> Hello
> I got mapinfo files (.DAT, .ID, .MAP, .TAB).
> I want to import this into QGIS, but I don’t get a vectorfile. I see
> only TAB-file.
> How can I convert the tab-files into vectorfiles.
> Does anaone have a solution.
> Thanks in advance,
> Jean Weijers
> Qgis-user mailing list
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekresources.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201217/4566b9ef/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201217/4566b9ef/attachment.png>
