[Qgis-user] Volume calculation - Reg
Kirk Schmidt
kirk at nortekresources.com
Fri Dec 18 05:40:44 PST 2020
Hi Mike:
I usually convert the contours or breaklines into a point layer and then
generate a dem from that. This is not a precise methodology but it
would depend on what you are trying to do and the precision of the
underlying data.
Kirk Schmidt
On 12/18/2020 5:28 AM, Michael Dufty wrote:
> The links for Nicolas are quite useful, but I think to create a raster
> DEM from vector lines you probably need to use the interpolate
> triangulation with breaklines or structure lines.
> The dialogue takes a bit of getting used to, you need to choose the
> layer the data will come from, click + then in the box below choose
> whether the layer is being used for points, breaklines or structure lines.
> I’ve had major issues with the interpolation crashing QGIS if I try to
> used it with breaklines for complex imported data, but it seems to
> work OK for simple test geometries, and may be good for a simple
> excavation.
> I’d be interested to know if anyone has had success with interpolation
> using breaklines for more complex data, I’ve had to resort to other
> software trying to import DEM supplied as dxf 3d faces, but maybe I’m
> missing a basic step like fixing geometry or removing duplicates.
> *From:*Qgis-user <qgis-user-bounces at lists.osgeo.org> *On Behalf Of
> *Nicolas Cadieux
> *Sent:* Friday, 18 December 2020 12:04 AM
> *To:* Abhi Shek <psn.abhishek at gmail.com>
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Volume calculation - Reg
> This should help
> https://youtu.be/EerXfUf-aHo <https://youtu.be/EerXfUf-aHo>
> https://www.pointsnorthgis.ca/blog/how-to-calculate-surfacecut-volume-qgis-advanced/
> <https://www.pointsnorthgis.ca/blog/how-to-calculate-surfacecut-volume-qgis-advanced/>
> Nicolas Cadieux
> https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
> Le 17 déc. 2020 à 04:57, Abhi Shek <psn.abhishek at gmail.com
> <mailto:psn.abhishek at gmail.com>> a écrit :
> Sir,
> I invite your kind attention to the above subject. I am a beginner
> in qgis.
> I want to create a raster DEM using Vector Lines.
> In a nutshell, I want to calculate the planned excavated volume.
> please guide me in this matter.
> with warm regards,
> P S N Abhishek,
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekresources.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201218/1147286b/attachment-0001.html>
