[Qgis-user] QGIS 3.xx not starting
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Mon Dec 21 07:49:50 PST 2020
I would start with the suggestion below. Then, I would update all the drivers and try to see what other software is normally auto loaded at startup to see what could be interfering with QGIS (like a anti malware). Concerning Quickheal, it may have blocked something at the installation so I would uninstall it (or disable it completely) and uninstall QGIS. Reboot, then reinstall QGIS.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 21 déc. 2020 à 00:35, Ujaval Gandhi <ujaval at spatialthoughts.com> a écrit :
> One of the original suggestions was to disable / uninstall your anti-virus and try launching qgis. Did you try that? From your description it looks like Quickheal might be interfering with qgis. Qgis has other dependencies on python, qt etc so merely allowing qgis may not be enough.
> Ujaval Gandhi
> Spatial Thoughts
>> On Mon, Dec 21, 2020, 9:41 AM K R Mayani <krmayani.procivil at gmail.com> wrote:
>> As one suggestion came from other source, I have tried opening QGIS with firewall off. So I tried to add .exes of python, qgis ltr, qgis in allowed program in QuickHeal, as its installed and managed firewall, but did not start.
>> So that strike me another idea. And I started the program in safe boot mode with network in windows 10. Surprisingly the program ran normally without crashing.
>> So can anyone give me any idea, what went wrong in normal boot mode? Because in safe boot, OS does not allow to connect through wifi and I, had to, mostly work with wifi.
>>> On Tue, Dec 8, 2020, 7:32 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com> wrote:
>>> Hi,
>>> Just a bunch of ideas...
>>> Did you have a working version before or is this a first time QGIS installation? You have 2 choices of installers on Windows, I would try with the second installer after removing the first version. Reboot the computer after the installation. Try Disabling your antivirus or adware software you could have when installing or starting QGIS, make sure your Windows and drivers are up to date. Do you have a second version of Python on your computer, or a software like ESRI that as it’s own version of Python? Perhaps there is a conflict between your QGIS python and the default python distribution? If this is not a new install, would you have a problématique python plugin in the plugin directory? Perhaps try removing those... Would you have weird character in your user directory like spaces or accents like “é”?
>>> Nicolas Cadieux
>>>>> Le 8 déc. 2020 à 07:07, K R Mayani <krmayani.procivil at gmail.com> a écrit :
>>>> Hi,
>>>> I am using QGIS 3.14.1 on my Laptop. I am having trouble with the software about its starting. After setting up python screen, it does not starts. I have also tried "run as administrator" but still the problem persists. With v3.10 and v3.14.1, the same problem is there. I have installed software again with "Run as Administrator" but the issue is not solved.
>>>> .NET 4.8 already installed.
>>>> osbuild: 19042.630
>>>> OS: Windows 10, home
>>>> Processor:AMDRyzen 5 3550H with Radeon Vega Mobile Gfx 2.10 GHz
>>>> RAM: 8.00 GB
>>>> crash: https://pastebin.com/5Tk75LTu
>>>> Which version should support my system rig?
>>>> Please help me with my trouble. Or suggest to me the steps.
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201221/1631bad8/attachment.html>
