[Qgis-user] FW: Re: Place feature label in one location during Temporal Animation - QGIS 3.16.1 - Windows 10
Andreas Neumann a.neumann at carto.net
Tue Dec 22 23:40:34 PST 2020
Hi Brent,
There is something called "Decorations" in QGIS where you can have
dynamic HTML content.
See https://anitagraser.com/2020/12/05/dashboards-in-qgis/ with a video
from Tim Sutton showing how to do dashboards in QGIS with decorations.
Andreas
On 2020-12-22 20:11, Brent Robertson wrote:
> Hi,
> I have an animation of an aircraft undertaking aerial topdressing (crop dusting).  I have it moving across time and showing it spreading fertiliser.
> What I am wanting to do is display the current air speed, which I can do as an offset to the aircraft position but I am wanting the air speed to be in one position within my map ie offset form the left lower corner.  Would be good to create some sort of dashboard showing air speed & altitude but would be happy with just being able to get a label showing in a single location.
> I have tried to set the location using the geometry generator, which doesn't work for me. Only using '$geometry' shows the label but changing to ' @map_extent_center ' my labels disappear.
> Also, tried to set as x & y under "Date defined" as for "Position (X)" as 'x(@map_extent_center)' and for "Position (Y)" as 'y(@map_extent_center)' but QGIS crashes.
> Any help would be appreciated.
> Thanks,
> Brent
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201223/fce3e739/attachment.html>
