[Qgis-user] Deployment customisation options
Paul Wittle paul.wittle at dorsetcouncil.gov.uk
Wed Dec 23 01:27:56 PST 2020
Quick update on my previous email. I've just found the --hide-browser option which deals with my specific example but perhaps is not very encouraging as needing a specific start-up option for it seems to imply it may not be possible to control the position of toolbars and things like that using any of the start-up options.
I'd be keen to hear other suggestions though?
Thanks,
Paul
Sent: 23 December 2020 09:04
To: qgis-user at lists.osgeo.org
Subject: Deployment customisation options
I'm trying to update our deployment of QGIS to use a more standard method of deployment and customisation and I was looking at the page in the manual. I noted the following options --customizationfile and --globalsettingsfile.
The customisation file ini turns off certain buttons from toolbars and panels and the global settings file configures things in the settings which is great; but, how do you specify which toolbars to display and where they are located?
At the moment the deployment loads but the toolbars are just loaded as default. In some cases I wanted them to be in the menu but not on the toolbar and I want to control which toolbars appear on which line of buttons. In the past I've done this by pushing out two profiles and just configured it in the qgis.ini file folder directly but this is not a good method really as there are lots of user specific settings in those files and it means I've had to create a script to do all that post install because I have to work in the users actual profile.
Is there a way to control the windows / panels and toolbars using either of the two ini files referenced?
To give a specific example; as default I tend to hide the 'Browser' window as our users are meant to use an internal data discovery tool and I like a bigger layers panel. I put:
[browser]
expandedPaths=favorites:
propertiesWidgetEnabled=false
propertiesWidgetHeight=@Variant(\0\0\0\x87\0\0\0\0)
Into the customisation file ini but that didn't work?
Thanks,
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/416433
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201223/de92e3b0/attachment.html>
