[Qgis-user] A few hours in the Training Manual
Etienne Trimaille
etienne.trimaille at gmail.com
Mon Dec 28 21:46:18 PST 2020
Thanks for your feedback.
The documentation team is doing their best to maintain this manual up to
date. But it's not easy.
You should create separate ticket in the github repository :
https://github.com/qgis/QGIS-Documentation
It will not be lost like emails.
Feel free to edit manually on github if you find some typo for instance.
For the "routes.shp", if you need to create a new layer (not adding an
existing file), you are indeed correct, but ALWAYS use the "..." button,
because it's a filepath, not filename. It will solve your problem.
Choose a directory where you have write permission.
Le mar. 29 déc. 2020 à 08:17, GARY PALMER <gpalmernc at icloud.com> a écrit :
> Here is a log of a few mostly happy hours spent in the training manual
> located at https://docs.qgis.org/3.16/en/docs/training_manual/index.html.
> Comments would be welcome. Gary. OS 10.15.7 (Catalina) on iMac Pro. QGIS
> 3.16.0-Hannover.
> 4.1.2 *Click on the Add New Map button*. There is no such button on the
> “Swellendam” window.
> 5.1.2 1. *Click on the Select Features button in the Attributes Toolbar.
> 2. Click on the feature that was just created and the remaining buttons
> will become enabled.* The remaining buttons do not become enabled.
> 5.1.5. *If the roads layer is not in your map, then add it from the
> GeoPackage file **training-data.gpkg** included in the **exercise_data**
> folder of the training data you downloaded.* At this point, I remember
> adding a portion of a GeoPackage file, but I don’t remember how. I am
> unsuccessful in using the menu Layer -> Create layer and Open Data Source.
> When I try to open the GeoPackage file I see a message that the file is
> read only. I try Menu Layer —> Add Layer —> Add Vector Layer —> … file
> dialog —> roads. This works. I feel a hint would be useful to avoid some
> flailing around. Just a note that we are adding an existing layer from the
> GeoPackage rather than creating a new layer would be helpful. Now I see the
> layer training_data_roads in the Layers box. It is checked and selected, it
> is the top layer, but no roads appear on the map. Now I will have to search
> back to where a vector layer was first imported from the GeoPackage. A
> numerical reference (2.2.3) and link would be useful here. I delete the
> “training_data_roads” layer and try again. I use the Open Data Source
> Manager and click on the GeoPackage tab. I add the roads, which appear on
> the map. Success, but painful and time-consuming success.
> I still need the routes.shp file, so I try Menu —> Create Layer —> New
> ShapeFile layer. I select Geometry Type line and add the new field “name”
> in the dialog box. Error message: Layer creation failed: Failed to create
> file routes.shp: Read-only file system. Without the shapefile, the vectors
> for the path and track can not be added.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201229/b6b5fe6d/attachment.html>
