[Qgis-user] QGIS multi user
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Thu Dec 31 01:20:01 PST 2020
Hi Raffaele,
One way to do it is having a proper central geo-database (e.g. PostGIS).
But if you are working with file-based layers (e.g. Geopackages), you can
use the Mergin service (http://public.cloudmergin.com/).
1- You and your colleagues can register with the service
2- Upload your project and data
3- Share it with your colleagues (Read access only in your case)
There is a plugin for QGIS to handle downloading, uploading and syncing of
the data (https://help.cloudmergin.com/working-with-qgis-plugin). They can
also view the project on their mobile devices using the Input app (
https://inputapp.io)
Kind regards
Saber
On Thu, 31 Dec 2020 at 09:04, Raffaele Ceretto <cerettoraffaele at gmail.com>
wrote:
> Good morning,
> I have a project on which I regularly draw lines and points. Only I can
> edit the project but I would like my colleagues to be able to open the
> project as read-only to see the changes. Is it possible to create multiple
> user and give them different privileges?
> Regards
> Qgis-user mailing list
Saber Razmjooei
www.lutraconsulting.co.uk
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20201231/fc969aca/attachment.html>
