[Qgis-user] bug in 3.10.2 (after upgrading from 3.10.1) with NULL being lost in PostGIS
Jason Carlson
jason at starlandcounty.com
Tue Feb 4 11:46:33 PST 2020
Hi Alessandro,
Thanks for your response.
I've only used the standalone installers so it took me a bit to figure out
how to start QGIS when using the OSGeo4W installer. My standalone was
version 3.10.2-0 and in the OSGeo4W installer I see a 3.10.2-2 as well as
the development version of 3.11.0-72.
Wasn't sure which one you meant. If you meant the 3.11.0-72 then the issue
is gone. If you had meant the 3.10.2-2 branch then it is still there but I
discovered more stuff that may help but won't explain until I confirm the
version I was to test against.
Jason
On Tue, Feb 4, 2020 at 9:05 AM Alessandro Pasotti <apasotti at gmail.com>
wrote:
> On Tue, Feb 4, 2020 at 5:02 PM Jason Carlson <jason at starlandcounty.com>
> wrote:
>> Can anyone else confirm this before I submit it?
> Can you please check latest master builds first? I've done a couple of
> fixes in the past few days that might have an impact on this issue.
> If the issue is still there, please file a ticket and attach a small SQL
> dump and a QGS project to reproduce the issue.
>> After I upgraded from 3.10.1 to 3.10.2 I noticed an issue that it no
>> longer handles null values correctly when updating records in PostGIS.
>> I rolled back to version 3.10.1 and the issue goes away.
>> Here is more detail:
>> I have some PostgreSQL tables that have fields that can be NULL or text
>> but I have check constraint in place saying it has to be NULL or one of a
>> list of specific strings.
>> In 3.10.1 if I go to edit a record that has some fields set as NULL, when
>> the QGIS attribute form loads for editing, it shows those fields as NULL
>> inside the text field (they can be text or null). I can make changes to any
>> fields and save and the NULL fields remain as NULL.
>> In 3.10.2 if I go to edit the same record, the QGIS attribute form when
>> displayed for editing the record does not show those fields as being NULL
>> but an empty string. When I submit changes, any fields that should still be
>> NULL are not being submitted as NULL as I get a check constraint error
>> saying it doesn't fit the criteria. I've tried entering into those fields
>> manually as NULL or 'NULL' or "NULL" and a dozen or so other guesses and it
>> still fails.
>> Again, if I roll back to version 3.10.1 it works as it has on many
>> previous versions all the way back to 2.8
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200204/a8c8836a/attachment.html>
