[Qgis-user] bug in 3.10.2 (after upgrading from 3.10.1) with NULL being lost in PostGIS
Jason Carlson
jason at starlandcounty.com
Tue Feb 4 14:44:33 PST 2020
It works great. I'll just roll back to the standalone 3.10.1 until they are
in the next version. Thanks :)
*Jason*
On Tue, Feb 4, 2020 at 1:36 PM Alessandro Pasotti <apasotti at gmail.com>
wrote:
> Hi Jason,
> the quickest way to test current master for your case is to unzip the
> latest build artifact for windows 64bits (it's a zip inside a zip) on your
> PC and launch the qgis.exe binary you find inside.
> No installation is required and it's completely standalone, there is no
> Python but you don't need it for your test case.
> On every commit the artifact is automatically built:
> https://github.com/qgis/QGIS/actions?query=workflow%3A%22Windows+cross+build+with+MXE%22
> The patches are very recent and they will be backported to 3.10 but I'll
> do that later this week.
> Let me know how it goes.
> On Tue, Feb 4, 2020 at 8:47 PM Jason Carlson <jason at starlandcounty.com>
> wrote:
>> Hi Alessandro,
>> Thanks for your response.
>> I've only used the standalone installers so it took me a bit to figure
>> out how to start QGIS when using the OSGeo4W installer. My standalone was
>> version 3.10.2-0 and in the OSGeo4W installer I see a 3.10.2-2 as well as
>> the development version of 3.11.0-72.
>> Wasn't sure which one you meant. If you meant the 3.11.0-72 then the
>> issue is gone. If you had meant the 3.10.2-2 branch then it is still there
>> but I discovered more stuff that may help but won't explain until I confirm
>> the version I was to test against.
>> Jason
>> On Tue, Feb 4, 2020 at 9:05 AM Alessandro Pasotti <apasotti at gmail.com>
>> wrote:
>>> On Tue, Feb 4, 2020 at 5:02 PM Jason Carlson <jason at starlandcounty.com>
>>> wrote:
>>>> Can anyone else confirm this before I submit it?
>>> Can you please check latest master builds first? I've done a couple of
>>> fixes in the past few days that might have an impact on this issue.
>>> If the issue is still there, please file a ticket and attach a small SQL
>>> dump and a QGS project to reproduce the issue.
>>>> After I upgraded from 3.10.1 to 3.10.2 I noticed an issue that it no
>>>> longer handles null values correctly when updating records in PostGIS.
>>>> I rolled back to version 3.10.1 and the issue goes away.
>>>> Here is more detail:
>>>> I have some PostgreSQL tables that have fields that can be NULL or text
>>>> but I have check constraint in place saying it has to be NULL or one of a
>>>> list of specific strings.
>>>> In 3.10.1 if I go to edit a record that has some fields set as NULL,
>>>> when the QGIS attribute form loads for editing, it shows those fields as
>>>> NULL inside the text field (they can be text or null). I can make changes
>>>> to any fields and save and the NULL fields remain as NULL.
>>>> In 3.10.2 if I go to edit the same record, the QGIS attribute form when
>>>> displayed for editing the record does not show those fields as being NULL
>>>> but an empty string. When I submit changes, any fields that should still be
>>>> NULL are not being submitted as NULL as I get a check constraint error
>>>> saying it doesn't fit the criteria. I've tried entering into those fields
>>>> manually as NULL or 'NULL' or "NULL" and a dozen or so other guesses and it
>>>> still fails.
>>>> Again, if I roll back to version 3.10.1 it works as it has on many
>>>> previous versions all the way back to 2.8
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Alessandro Pasotti
>>> w3: www.itopen.it
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200204/168fed8f/attachment.html>
