[Qgis-user] [Qgis-community-team] 3D view of LIDAR data city of boulder
Alexandre Neto
senhor.neto at gmail.com
Mon Feb 10 02:15:08 PST 2020
Thanks Saber, I will take a look.
Alex Neto
A segunda, 10/02/2020, 09:05, Saber Razmjooei <
saber.razmjooei at lutraconsulting.co.uk> escreveu:
> Hi Alexandre,
> I am not sure about the licensing of the data.
> For mesh layer, there are already some datasets for test suite, which
> should be good for documentation too:
> https://github.com/lutraconsulting/MDAL/tree/master/tests/data
> Kind regards
> Saber
> On Sun, 9 Feb 2020 at 12:48, Alexandre Neto <senhor.neto at gmail.com> wrote:
>> Can we consider creating/clipping a open 3D sample data that we could add
>> to QGIS Sample data?
>> This would be useful for when someone else wants to update the
>> documentation.
>> Same goes for mesh data.
>> Thanks,
>> Alexandre Neto
>> A sábado, 8/02/2020, 12:38, Saber Razmjooei <
>>> Hi Larissa,
>>> Apologies. Boulder data indeed contain walls and roofs.
>>> To view the data in 3D, you need to go to each layer and open
>>> Properties > 3D view and change the style to Single symbol.
>>> Also, the dataset is very large. It would be easier if you crop the data
>>> to a smaller area.
>>> Regards
>>> Saber
>>> On Sat, 8 Feb 2020 at 12:00, Saber Razmjooei <
>>> saber.razmjooei at lutraconsulting.co.uk> wrote:
>>>> Hi Larissa,
>>>> Many thanks for looking into documenting this.
>>>> I had a quick look at the data. It is only the footprint. So, you can
>>>> only extrude the data (based on height).
>>>> There is a good data source of 3D buildings here:
>>>> https://github.com/wonder-sk/3d-spatial-data
>>>> And for building in New York, we wrote a blog post here. The data have
>>>> z-valuse and should automatically get picked up by the 3D map view.
>>>> https://www.lutraconsulting.co.uk/blog/2017/10/16/buildings-in-qgis3d/
>>>> Feel free to use any of the content from our website in the
>>>> documentation.
>>>> Kind regards
>>>> Saber
>>>> On Fri, 7 Feb 2020 at 13:59, Larissa Junek <l.junek at gmx.net> wrote:
>>>>> Hello folks,
>>>>> for documentation purposes I'd like to visualize the 3d data of the
>>>>> city
>>>>> of boulder in qgis 3.10 .
>>>>> https://bouldercolorado.gov/open-data/city-of-boulder-3d-buildings/
>>>>> Unfortunately qgis crashes when loading the shapefile into the 3d view.
>>>>> Also, where do I have access to the z-coordinate so that there will be
>>>>> a
>>>>> 3d view. At the moment there is only visible a plane with the vectors
>>>>> but no "z-value" in the 3d view application. Extrusion doesn't help
>>>>> solute the problem.
>>>>> There is a hint that these data have something to do with GeoJSon, so
>>>>> maybe I have to find another 3d data suitable for using in the 3D view
>>>>> application.
>>>>> Can somebody help?
>>>>> Cheers, Larissa
>>>>> _______________________________________________
>>>>> Qgis-community-team mailing list for organizing community resources
>>>>> such as documentation, translation etc..
>>>>> Qgis-community-team at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
>>>> Saber Razmjooei
>>>> +44 (0)7568 129733
>>> Saber Razmjooei
>>> +44 (0)7568 129733
>>> Qgis-community-team mailing list for organizing community resources such
> Saber Razmjooei
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200210/37a469a2/attachment.html>
