[Qgis-user] Qgis polygon tool
    Mike Bartholomew
    mikeb at alyrica.net
    Mon Feb 17 23:38:13 PST 2020
Hello Alexandre,
OS is Windows 10 and the Qgis version is 3.4.15. Was just using the default style to begin with.
I think I was confused that the dialog box opened and the polygon disappeared. I added text for the id, pressed OK and it is working. I knew it would be something simple, but just didn’t get there.
Thank you,
Mike
Sent from Mail for Windows 10
Sent: Monday, February 17, 2020 11:30 PM
To: Mike Bartholomew
Cc: QGIS User
Subject: Re: [Qgis-user] Qgis polygon tool
Hi mike,
You seem to be doing everything right. You click with the left button for a while and you finish with the right-click.
The dialog is normal to appear. Just press OK.
What version of QGIS are you using? In which OS?
What  CRS are you using.
Do you have any filter or special style associated with your layer?
Try adding some existing data beforehand to make sure you are digitising in a logical place (in the context of the CRS)
Alexandre Neto
QGIS Support
www.qcooperative.net
A terça, 18/02/2020, 07:17, Mike Bartholomew <mikeb at alyrica.net> escreveu:
I am new to Qgis and have been following tutorials to learn. I am having difficulty with the polygon tool. First I created a new Shapefile Layer, selected Polygon as the Geometry type, left the Fields list alone, so have a default id Field, gave it a file name (test) and saved it. Then I right-clicked on the layer and selected Toggle Editing. I can then draw a polygon on my map but when finished the right mouse button opens a dialog box with the following:
test – Feature Attributes
Actions
id NULL
It has a choice of 2 buttons, OK and Cancel, but neither seem to work and the polygon I created is erased. The first time I created a layer and added a polygon it worked, but in subsequent tries I keep getting the above dialog box and the polygon is erased.
I’ve looked through old messages and found that right clicking outside the map area was the solution, but that is not working either. This seems like a simple exercise, but I am at a loss as to why this quit working.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200217/dbb323ed/attachment.html>
