[Qgis-user] Referer
Jonathan Moules jonathan-lists at lightpear.com
Sat Feb 22 11:49:53 PST 2020
Hi Christoph,
Interesting info. Although HTTP Referer isn't a GI thing, it's a HTTP
thing; far pre-dating WMS. ESRI do similar non-standard things with the
standard HTTP headers.
Cheers,
Jonathan
On 22/02/2020 19:23, Christoph Jung wrote:
> Hello Jonathan,
> I just misinterpreted the word “referer”. The reason for it in a nutshell:
> My company uses Smallworld as the main gis and we have an extension to
> display WMS layers in a more user friendly way (it is easier then the
> standard WMS function, but very “Smallworld-like” anyway ^^). There is
> a config file  with the URLs of the services and also a ”referer” for
> each of them: the copyright respectively the owner of the WMS. This
> information will be displayed in the map view after making a WMS Layer
> visible. I just saw an input field in QGIS named referer and thought,
> it would be the same like in Smallworld. But one more thing Smallworld
> is very different to other GI systems :D
> Sincerely,
> Christoph
>> Am 21.02.2020 um 22:49 schrieb Jonathan Moules
>> <jonathan-lists at lightpear.com>:
>> Hi Christoph,
>> What do you mean by "where will this referer be displayed"? I'm
>> guessing this is the HTTP referer in which case it's probably going
>> to be sent as a HTTP Header with every request WMS/XYZ request that
>> QGIS is making to the server (what I'd expect anyway). I guess this
>> is useful because for "security" reasons some servers only respond to
>> specific referers. The server operator will see it in their logs but
>> otherwise it's going to be invisible.
>> Cheers,
>> Jonathan
>> On 18/02/2020 14:04, Christoph Jung wrote:
>>> Hello everybody,
>>> When configuring a new WMS or XYZ connection, I can insert a referer. Where will this referer be displayed?
>>> Sincerely,
>>> Christoph
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200222/21c7be99/attachment.html>
