[Qgis-user] Disabled Edit Layers on Oracle Connection
Julien Cabieces
julien.cabieces at oslandia.com
Mon Feb 24 01:23:18 PST 2020
I removed the limitation for 3D geometries in this PR:
https://github.com/qgis/QGIS/pull/3362
So, it should be possible to edit Oracle 3D geometries in QGIS 3.12. Let me
know if it still doesn't work.
Regards,
Julien
> Hi,
> It seems it can’t handle 3D geometries...
> Nicolas Cadieux
>> Le 18 févr. 2020 à 13:26, Eduardo Fernández Fernández <eduardoff at consorcioasturias.com> a écrit :
>> The message panel shows this:
>> <image002.png>
>> Any idea?
>> De: Prud'homme Jérémie <p.jeremie at gmail.com>
>> Enviado el: martes, 18 de febrero de 2020 12:25
>> Para: Eduardo Fernández Fernández <eduardoff at consorcioasturias.com>
>> CC: qgis-user at lists.osgeo.org
>> Asunto: Re: [Qgis-user] Disabled Edit Layers on Oracle Connection
>> Hi,
>> I had the same problem.
>> See http://osgeo-org.1560.x6.nabble.com/Editing-Oracle-table-can-t-add-feature-td5423980.html
>> For me the root of the issue was having 3D geometries with SRID 2154 in the Oracle table. With 2D geometries it is ok.
>> But I noticed I don't have the SRID and primary key filled in the "add oracle layer" menu... and I don't know why.
>> Jérémie.
>> Le mar. 18 févr. 2020 à 12:14, Eduardo Fernández Fernández <eduardoff at consorcioasturias.com> a écrit :
>> Hi,
>> I use Qgis 3.10.2-A Coruña.
>> I have made a connection to BD oracle 12c (standard version) without problemas and I can perfectly see all the objects and edit attributes but the digitizing options are disabled. I can’t add, move, paste…spatial objets.
>> I already tried with the scheme user owner and with another user with permissions on all tables but the result is the same. Is it necessary to give permissions in some other scheme or tables? Is it not possible to edit space objects in the standard version?
>> <image001.png>
>> Thank you.
>> Regards.
>> - Puede agilizar sus trámites con nosotros accediendo a nuestra web en www.consorcioasturias.com o usando nuestra app gratuita que puede descargar desde Google Play buscando CTA ASTURIAS -
>> - Le informamos que su dirección de correo electrónico, así como el resto de los datos de carácter personal aportados, serán objeto de tratamiento automatizado en nuestros ficheros, con la finalidad de gestionar la agenda de contactos de nuestra entidad y poder atender a sus peticiones de consulta por vía electrónica. Vd. podrá en cualquier momento ejercer el derecho de acceso, rectificación, cancelación, limitación, portabilidad y oposición en los términos establecidos en el Reglamento (UE) 2016/679 mediante notificación escrita con copia de DNI a CONSORCIO DE TRANSPORTES DE ASTURIAS, Avenida Julián Clavería, 11, 33006, Oviedo - Asturias. Puede consultar información adicional en www.consorcioasturias.com.
>> - Este mensaje se dirige exclusivamente a su destinatario y puede contener información privilegiada o confidencial. Si no es Vd. el destinatario indicado, queda notificado de que la utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. Si ha recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente por esta misma vía y proceda a su destrucción. -
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
