[Qgis-user] Polygonize - No result
    Bo Victor Thomsen
    bo.victor.thomsen at gmail.com
    Tue Jan  7 02:57:50 PST 2020
The problem is that the *stand-alone* installation of QGS 3.10 (64 bit
at least) doesn't set the PYTHONPATH environment variable, so the python
interpreter can't find the module. However, the "*network installation*"
of the same QGIS version do set the variable. And that version works
without a hitch
If you add a custom variable *PYTHONPATH* with value
*C:\PROGRA~1\QGIS3~1.10\apps\Python37;C:\PROGRA~1\QGIS3~1.10\apps\Python37\Scripts
*to the stand-alone  version of QGIS 3.10 (and restart the program) the
"polygonize (raster to vector)" works in this version too.
So I suspect we might have a packaging problem with with the stand-alone
installation
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 07-01-2020 kl. 10:08 skrev Luigi Pirelli:
> do you have python_gdal installed and/or check that gdal_polygonize.py
> is available... a osgeo4w packaging problem can result in
> associate gdal_polygonize.py to a interpreter. In this case, just link
> or copy/remane gdal_polygonize.py as gdal_polygonize
> Luigi Pirelli
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Book: Mastering QGIS3 - 3rd Edition
> <https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
> * Hire a team: http://www.qcooperative.net
> On Sun, 5 Jan 2020 at 21:43, Lene Fischer <lfi at ign.ku.dk
> <mailto:lfi at ign.ku.dk>> wrote:
>     Hi
>     I´m trying to run Vector to raster (polygonize)
>     Suspect it´s the path to GDAL.
>      I get this error message
>     QGIS version: 3.10.1-A Coruña
>     QGIS code revision: ef24c526da
>     Qt version: 5.11.2
>     GDAL version: 3.0.2
>     GEOS version: 3.8.0-CAPI-1.13.1
>     PROJ version: Rel. 6.2.1, November 1st, 2019
>     Processing algorithm…
>     Algorithm 'Polygonize (raster to vector)' starting…
>     Input parameters:
>     { 'BAND' : 1, 'EIGHT_CONNECTEDNESS' : False, 'EXTRA' : '', 'FIELD'
>     : 'DN', 'INPUT' : 'C:/gis/nysted_raster/1_7m.tif', 'OUTPUT' :
>     'TEMPORARY_OUTPUT' }
>     GDAL command:
>     python3 -m gdal_polygonize C:\gis\nysted_raster\1_7m.tif
>     C:/gis/temp/processing_dc13c7a2a0cf4d22aef37dcd462534db/e5db8073dc414a989e176ea591f28c1c/OUTPUT.gpkg
>     -b 1 -f "GPKG" OUTPUT DN
>     GDAL command output:
>     '\\a00143.science.domain\dlt265\Documents'
>     CMD.EXE was started with the above path as the current directory.
>     UNC paths are not supported. Defaulting to Windows directory.
>     C:\PROGRA~1\QGIS3~1.10\bin\python3.exe: No module named
>     gdal_polygonize
>     Execution completed in 0.33 seconds
>     Results:
>     {'OUTPUT':
>     'C:/gis/temp/processing_dc13c7a2a0cf4d22aef37dcd462534db/e5db8073dc414a989e176ea591f28c1c/OUTPUT.gpkg'}
>     Loading resulting layers
>     The following layers were not correctly
>     generated.<ul><li>C:/gis/temp/processing_dc13c7a2a0cf4d22aef37dcd462534db/e5db8073dc414a989e176ea591f28c1c/OUTPUT.gpkg</li></ul>You
>     can check the 'Log Messages Panel' in QGIS main window to find
>     more information about the execution of the algorithm.
>     Regards
>     Lene Fischer
>     Associate Professor
>     University of Copenhagen
>     Department of Geoscience and Natural Resource Management
>     Forest and Landscape College
>     Nødebovej 77a
>     3480 Fredensborg
>     Denmark
>     MOB +45 40115084
>     lfi at ign.ku.dk <mailto:lfi at ign.ku.dk>
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200107/84680c8f/attachment-0001.html>
