[Qgis-user] QGIS slows PC to a point it is unusable
Alexandre Neto senhor.neto at gmail.com
Thu Jan 9 15:21:05 PST 2020
Hi Peter,
Try to use Spatialite, Geopackage or (even better) PostGIS to store your
data and create indexes both on the geometries, but also on the fields used
on the rules you mentioned. That can give you a nice boost.
Hope it helps,
Alexandre Neto
QGIS Support
www.QCooperative.net
A quinta, 9/01/2020, 20:42, Peter Cornelissen <peter at cornelissen.org.uk>
escreveu:
> Hi
> I am finding that although my ShapeFIle tables in QGIS are not huge, my
> Windows 10 PC virtually comes to a grinding halt and becomes unusable once
> I get to something like 50 layers. I am using about 6 or 7 ShapeFiles with
> different filters. I think it is related to the fact that approx. most of
> them having a rule based styles, some with about 20 rules per layer.
> Restarting the PC sorts things out for a while, but soon as I start
> working on the project it quickly gets slower and again comes to a point
> where it again slows right down.
> I've not seen anything relate to this issue online and I've seen tables
> which must be huge. Is it likely to be my PC or am I using the wrong
> methods? Would I be better using SpatiaLite to store the tables?
> Thought?
> Peter
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200109/118e9c7e/attachment.html>
