[Qgis-user] Problem with xyz tiles
Christoph Jung
jagodki.cj at gmail.com
Fri Jan 31 00:21:32 PST 2020
Thank you for this advice, Alessandro. Now it works like a charm :)
Sincerely,
Christoph
> Am 30.01.2020 um 16:20 schrieb Alessandro Pasotti <apasotti at gmail.com>:
>> On Thu, Jan 30, 2020 at 1:43 PM Christoph Jung <jagodki.cj at gmail.com> wrote:
>> Hi Víctor,
>> Thank you for your advice. Yes, my tiles are in the opposite order in vertical direction. But only if I implement them via xyz tiles with a url like http://abc.def/{z}/{x}/{y}.png the tiles are in the wrong vertical order. Is there a possibility to adjust the values QGIS is using for the http parameters using an equation or something else?
> Use "-y" for inverted Y
> If I'm not wrong it's documented in the tooltip when you add/edit the URL.
> Cheers
>> Sincerely,
>> Christoph
>>>> Am 30.01.2020 um 10:06 schrieb Víctor Centella <vcentella at prodevelop.es>:
>>> Hello Christoph,
>>> I had a similar issue, but not using mbtiles but generating tiles XYZ as files. I could solve it using the "Use inverted tile Y axis (TMS convention)" option, but this option is not available in the "Generate tiles XYZ (MBtiles)" tool, it is only in the "Generate tiles XYZ (Directory)" tool.
>>> <jlkjanhadjbghdkp.png>
>>> Regards,
>>> Víctor
>>>> El 30/01/2020 a las 7:38, Christoph Jung escribió:
>>>> Hello everyone,
>>>> I have an mbtiles file with OSM-tiles. If I drag and drop this file into QGIS, everything looks fine. Then I started a tomcat Server for providing these tiles via url in my company and created a new connection for xyz tiles in the QGIS browser. But the tiles are not on the right position. And they are internally mixed too, i.e. the tiles are not in correct vertical order in the map view. The settings of the xyz tiles connection should be okay. Have had anybody a similar problem in the past? Is it possible to get the GetMap-requests (or the similar name for xyz tiles), QGIS is generating for the map view, logged or printed to the python console?
>>>> Sincerely,
>>>> Christoph
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Víctor Centella Fuster
>>> Prodevelop
>>> http://www.prodevelop.es
>>> <logo 25 años prodevelop.png>
>>> Aviso legal:
>>> Este mensaje se dirige exclusivamente a su destinatario y puede contener información privilegiada o confidencial. Si ha recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente por esta misma vía y proceda a su destrucción.
>>> De acuerdo con la nueva Ley de Servicios de la Sociedad de la Información y Comercio Electrónico aprobada por el Parlamento Español y de lo establecido en el Reglamento (UE) 2016/679 del Parlamento Europeo de Protección de Datos de Carácter Personal, le comunicamos que su dirección de correo electrónico forma parte de un tratamiento automatizado. Tiene usted derecho de oposición, acceso, rectificación, cancelación, y portabilidad de sus datos, mediante una respuesta a este e-mail. Asimismo, podrá dirigirse a la Autoridad de Control competente para presentar la reclamación que considere oportuna.
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200131/b9a10900/attachment.html>
