[Qgis-user] PDF Georefernces
Martin Bittens
martin.bittens at gmx.de
Mon Jul 13 04:06:26 PDT 2020
Hello Warren,
if you have some locations in the pdf-file with known coordinates you
can do the following (for me this procedure works fine in most of the
cases):
1.) Convert the pdf-file into *.tif or *.jpg;
2.) In QGIS open the georeferencer tool (you can find it in the raster
tab of the QGIS main window);
3.) Import the *.tif/*.jpg file into the georeferencer tool;
4.) Add the coordinates of the known locations into the imported map by
using the "add point" button on top;
5.) Open "Settings --> Transformation Settings", complete the setting
options, and click on "OK";
6.) Click on "Start Georeferencing" (the green triangle on top);
Then you should get what you wanted...!
Regards
Martin
Am 7/13/2020 um 1:36 AM schrieb Warren Thorne:
> Hi all,
> Thanks for the welcome to the group. I have some PDF’s from historic
> reports I want to georeference and import into QGIS, is this possible?
> *Warren Thorne*
> *Principal Geologist*
> Mineral Resources Limited <http://www.mineralresources.com.au/>
> 1 Sleat Rd, Applecross, Western Australia 6153
> *P *+61 8 9329 3600 *F *+61 8 9329 3601 *M *
> *E *warren.thorne at mrl.com.au <mailto:warren.thorne at mrl.com.au> *W
> *www.mineralresources.com.au <http://www.mineralresources.com.au>
> IMPORTANT PLEASE READ - Email Disclaimer
> This email message (including any attachments) is intended only for
> the addressee(s) and is to be kept strictly confidential unless
> otherwise agreed in writing with its sender. If you are not the
> intended recipient please notify the sender by reply email and
> immediately delete this email. Use, disclosure or reproduction of this
> email (or any of its attachments) by anyone other than the intended
> recipient(s) is strictly prohibited. No representation is made that
> this email or any attachments are free of viruses. Virus scanning is
> recommended and is the responsibility of the recipient.
> Qgis-user mailing list
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200713/6ff50e46/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200713/6ff50e46/attachment-0001.gif>
