[Qgis-user] What is a correct input or ouput for "Order by expression" algorithm ?
Yann Voté ygversil at lilo.org
Mon Jul 13 05:22:20 PDT 2020
Hi all,
I'm trying to use the "Order by expression" algorithm in a processing model.
Before this algorithm I manipulate input layers (remove and refactor
columns). After it, I export ordered layers to CSV as a final result
(then I want to diff CSV files, that's why I need ordered output).
But it seems to not work. Layers are not ordered at all. The help
message says: "Be careful, it might not work as expected with some
providers, the order might not be kept every time." But which providers
are working ?
There is also this Github issue:
https://github.com/qgis/QGIS/issues/29794 which does not provide helpful
feedback.
Does anybody know what is the correct way to use the "Order by
expression" algorithm ? Or any workaround to acheive the same effect ?
Thanks.
Yann Voté - ygversil at lilo.org
