[Qgis-user] reproduced in dev. version - was Re: graphical modeler, field calculator, NULL result but no error report
James Powell
powellj at pdx.edu
Mon Jul 13 17:29:03 PDT 2020
I am able to reproduce this behavior in the development version of qgis.
As a consequence, I opened two issues:
"Python call to --processing.run('qgis:fieldcalculator'-- fails to catch
divide by zero"
(https://github.com/qgis/QGIS/issues/37737)
"nonsense code causes infinite regress in error reports"
(https://github.com/qgis/QGIS/issues/37739). Both have since been
tagged as "Bug + Processing + Modeller".
I learned along the way from a comment in the qgis core source code that
the syntax of the language for the FORMULA argument, which I think is
called "Processing", is SQL or SQL-ish by design.
- JP
On 6/17/20 4:00 PM, James Powell wrote:
> Hi there everybody,
> I want to derive some floating point values using an expression in the
> field calculator (see model snapshot below). I'm using qgis 3.10.6 on
> Debian 10.
> I am finding that the first field calculator call, which produces
> 'dbgfieldcalc',
> gives only NULL answers.
> The second field calculator call (at the bottom, which produces
> 'dbgfishnetFinal')
> does almost the same thing and it works great.
> At no time will running this model produce errors. In fact, even
> changing attribute names to be invalid attribute names doesn't produce
> an error at all.
> What I expect:
> - That the field calculator is able to consistently run simple
> expressions through.
> - That feeding invalid attribute names causes an error report and
> aborts the model run.
> I've read through the docs that show up for a search on "qgis-user
> field calculator".
> The python code produced for this model reads
> : # Field calculator
> : alg_params = {
> : 'FIELD_LENGTH': 10,
> : 'FIELD_NAME': 'emissionsAfterFishnetInGramPerHour',
> : 'FIELD_PRECISION': 3,
> : 'FIELD_TYPE': 0,
> : 'FORMULA': 'attribute($currentfeature,
> \'emissionsingramsperhour\') * attribute($currentfeature,
> \'xlength_2\') / attribute($currentfeature, \'length\')',
> : 'INPUT': outputs['AddGeometryAttributes']['OUTPUT'],
> : 'NEW_FIELD': True,
> : 'OUTPUT': parameters['Dbgfieldcalc']
> : outputs['FieldCalculator'] =
> processing.run('qgis:fieldcalculator', alg_params, context=context,
> feedback=feedback, is_child_algorithm=True)
> : results['Dbgfieldcalc'] = outputs['FieldCalculator']['OUTPUT']
> where "xlength_2" is a nonexistent attribute (but the script has the
> same behavior when I use
> "length_2", which is an existent attribute).
> Is it usual to not detect errors like this? Is there some reason the
> expression I
> wrote (with the proper attribute name) wouldn't give a floating point
> number, but produces NULL instead?
> many thanks,
> James P.
> snapshot:
> James E. Powell, MS
> Pronouns: he/him/his
> Applied Physics PhD Candidate
> Department of Physics
> Portland State University
> Home page:http://web.pdx.edu/~powellj
> Office: SRTC 409B Phone: +1-503-725-8515
James E. Powell, MS
Home page: http://web.pdx.edu/~powellj
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200713/39f2497d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200713/39f2497d/attachment-0001.png>
