[Qgis-user] use the new standalone console processing tool, in a server without a GUI
aborruso
aborruso at gmail.com
Tue Jul 14 15:18:53 PDT 2020
Hi Jurgen,
Jürgen E. Fischer wrote
> Bullseye is debian (but as ubuntu is a symlink to debian that doesn't
> matter
> anyway) and not yet supported. You could try unstable.
I have added unstable. Now when I run "sudo apt-get install qgis", I have
The following packages have unmet dependencies:
qgis : Depends: libqgis-3d3.14.0 but it is not going to be installed
Depends: libqgis-analysis3.14.0 but it is not going to be installed
Depends: libqgis-app3.14.0 but it is not going to be installed
Depends: libqgis-core3.14.0 but it is not going to be installed
Depends: libqgis-gui3.14.0 but it is not going to be installed
Depends: libqt5core5a (>= 5.12.2) but 5.11.3+dfsg1-4 is to be
installed
Depends: libqt5webkit5 (>= 5.212.0~alpha3) but it is not going to be
installed
Depends: python3-qgis (= 1:3.14.0+99unstable-1) but it is not going
to be installed
Depends: qgis-providers (= 1:3.14.0+99unstable-1) but it is not
Recommends: qgis-plugin-grass but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Do I must install all the packages in this list? If yes, via apt or pip?
Thank you
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
