[Qgis-user] 200717 - How do I enclose an orthogonal grid of points with a polygon boundary.
Håvard Tveite
havard.tveite at nmbu.no
Fri Jul 17 01:00:58 PDT 2020
Hi Paul,
I don't think you will find a function in QGIS to do this,
but you should be able to achieve it by using the following
procedure:
1) Create a polygon grid with the same "spacing" as your point grid.
Use the "Create grid" algorithm (from the Processing Toolbox), with
Grid type: Rectangle (Polygon)
Grid extent: Click on the ... pull-down and select "Calculate from
layer", and select your point layer
Horizontal spacing: 25 meters
Vertical spacing: 100 meters
2) Run the "Join attributes by location (summary)" algorithm with
Input layer: the generated polygon grid from the first step
Join layer: your point grid
Geometric predicate: "intersects"
3) Run the algorithm "Select by Attribute" with
Input layer: your "Joined layer" (from step two)
Selection attribute: one of the *_count attributes
Operator: =
Value: 4
Modify current selection by: creating new selection
4) Run the "Dissolve" algorithm with
Input layer: your "Joined layer" from step 2-3
check "Selected features only"
This should work (but rounding errors may cause problems in
step two and four)
Håvard
On 17.07.2020 07:21, Paul T A Drea wrote:
> Hello list,
> I hope this finds everyone safe and healthy during these trying times.
> I am using a MacBook Pro running macOS 10.15 (Catalina).
> QGIS version 3.14.0-Pi. QGIS code revision 9f7028fd23.
> I have a shp file containg 2 653 337 points in an orthononal grid with
> 25m x 100m spacing of the points.
> The grid is oriented north south. These points are in lines spaced 25m
> in the easting (X) direction and 100m northing (Y) direction.
> I would like to apply a polygon as a boundary (red) as shown in the
> screen grab below.
> I have not been able to achieve this using convex hull as the final
> output does not take into acount the sawtooth steps.
> Any help or pointers would be appreciated thanks.
> I am not a coder and have no knowledge of writing any scripts.
> Thanks and Best regards,
> Paul
> */Paul T. A. Drea/*
> *Geodetic Consultant*
> *Cell Greece: +30-698 052 0611*
> *Cell Abu Dhabi: +971 50 595 6547*
> *Cell U.K.: +44 7507 975162*
> *SKYPE: paul.drea*
> *e**-mail 1: **pauldrea at gmail.com* <mailto:pauldrea at gmail.com>
> *e**-mail 2: **ptadrea at otenet.gr* <mailto:ptadrea at otenet.gr>
