[Qgis-user] How to install QGIS in Debian 11?
aborruso
aborruso at gmail.com
Fri Jul 17 03:53:30 PDT 2020
I'm not able to install QGIS in Debian 11.
My steps
sudo add-apt-repository "deb https://qgis.org/debian unstable main"
sudo apt-get update
sudo apt-get install qgis
I have these errors:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
qgis : Depends: libqgis-3d3.14.0 but it is not going to be installed
Depends: libqgis-analysis3.14.0 but it is not going to be installed
Depends: libqgis-app3.14.0 but it is not going to be installed
Depends: libqgis-core3.14.0 but it is not going to be installed
Depends: libqgis-gui3.14.0 but it is not going to be installed
Depends: libqt5core5a (>= 5.12.2) but 5.11.3+dfsg1-4 is to be
installed
Depends: libqt5webkit5 (>= 5.212.0~alpha3) but it is not going to be
installed
Depends: python3-qgis (= 1:3.14.0+99unstable-1) but it is not going
to be installed
Depends: qgis-providers (= 1:3.14.0+99unstable-1) but it is not
Recommends: qgis-plugin-grass but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
How to solve these?
Thank you
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
