[Qgis-user] What am I missing? Python plugins not available.
Charles Dixon-Paver
charles at kartoza.com
Mon Jul 20 07:20:51 PDT 2020
Python3 may be installed already. Try run "python3 --version" in the
terminal
On Mon, 20 Jul 2020 at 15:57, Jo <winfixit at gmail.com> wrote:
> Install a python 3 version.
> Jo
> On Mon, Jul 20, 2020, 15:49 F@ <f at donghi.co.uk> wrote:
>> Thank you.
>> Incase it helps:
>> Franks-iMac:~ Frank$ python --version
>> Python 2.7.10
>> Warm regards,
>> Frank
>> On 20 Jul 2020, at 13:37, ISA Solutions support <
>> support at isasolutions.com.au> wrote:
>> Yes I had this problem on my Mac and can confirm it was because python
>> wasn’t being picked up by qgis. It was installed, but qgis wasn’t using it.
>> I can’t recall how I fixed it...will have a look in the morning.
>> Sent from my iPad
>> On 20 Jul 2020, at 9:49 pm, F@ <f at donghi.co.uk> wrote:
>> Hi,
>> I should have posted a better screen shot. My installed plugins list is
>> the same as the All plugins list.
>> <Screen Shot 2020-07-20 at 12.45.33.png>
>> Hence my question about missing plugins.
>> Warm regards,
>> Frank
>> On 17 Jul 2020, at 15:53, Nicolas Cadieux <njacadieux.gitlab at gmail.com>
>> wrote:
>> Hi,
>> You are looking at the installed plugins only. Click on All and you
>> should see your plugin in the lists, if it’s experimental, it will only
>> show up if you apply the proper settings in the setting tab.
>> Nicolas Cadieux
>> Ça va bien aller!
>> Le 17 juill. 2020 à 10:17, F@ <f at donghi.co.uk> a écrit :
>> Hi list,
>> This is new to me so apologies if something not complete.
>> I am on a iMac late 2013 running MacOS Sierra 10.12.6
>> I have the standard stable QGIS install 3.8.1 (full info below)
>> I wish to upload a map to qgiscloud or package it so that another user
>> can download the map.
>> For some reason I am missing the python plugins.
>> <Screen Shot 2020-07-17 at 15.08.41.png>
>> Any help/guidance very welcome.
>> I have looked into installing an older copy of QGIS for the macOS, but
>> worried I will lose all my work.
>> Warm regards,
>> Frank
>> Full QGIs info:
>> QGIS version
>> 3.8.1-Zanzibar
>> QGIS code revision
>> dcd95cc648 <https://github.com/qgis/QGIS/commit/dcd95cc648>
>> Compiled against Qt
>> 5.12.3
>> Running against Qt
>> 5.12.3
>> Compiled against GDAL/OGR
>> 2.4.1
>> Running against GDAL/OGR
>> 2.4.1
>> Compiled against GEOS
>> 3.7.2-CAPI-1.11.2
>> Running against GEOS
>> 3.7.2-CAPI-1.11.2 b55d2125
>> PostgreSQL Client Version
>> 11.3
>> SpatiaLite Version
>> 4.3.0a
>> QWT Version
>> 6.1.4
>> QScintilla2 Version
>> 2.11.1
>> Compiled against PROJ
>> 5.2.0
>> Running against PROJ
>> Rel. 5.2.0, September 15th, 2018
>> OS Version
>> macOS Sierra (10.12)
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200720/2d0a0ee2/attachment.html>
