[Qgis-user] What am I missing? Python plugins not available.
Charles Dixon-Paver
charles at kartoza.com
Tue Jul 21 02:40:46 PDT 2020
It may not necessarily be that python is not being picked up by QGIS then.
I am probably not the authority on this, but I believe there was an update
to the plugin system which may have gone awry. As suggested previously,
this might be resolved by upgrading to a newer version of QGIS (e.g. 3.10
LTS)
One thing you could possibly try is checking the plugin repository source
in the plugin settings and reloading it or adding the plugins.qgis.org repo
(if it is not already there).
My plugin repository for 3.10 is
https://plugins.qgis.org/plugins/plugins.xml
I'm not sure if that's the correct one for your version, so maybe someone
else can comment.
[image: image.png]
On Tue, 21 Jul 2020 at 10:20, <f at donghi.co.uk> wrote:
> Yes
> Franks-iMac:~ Frank$ python3 --version
> Python 3.8.4
> Sent from my iPhone
> On 20 Jul 2020, at 14:56, Jo <winfixit at gmail.com> wrote:
> Install a python 3 version.
> Jo
> On Mon, Jul 20, 2020, 15:49 F@ <f at donghi.co.uk> wrote:
>> Thank you.
>> Incase it helps:
>> Franks-iMac:~ Frank$ python --version
>> Python 2.7.10
>> Warm regards,
>> Frank
>> On 20 Jul 2020, at 13:37, ISA Solutions support <
>> support at isasolutions.com.au> wrote:
>> Yes I had this problem on my Mac and can confirm it was because python
>> wasn’t being picked up by qgis. It was installed, but qgis wasn’t using it.
>> I can’t recall how I fixed it...will have a look in the morning.
>> Sent from my iPad
>> On 20 Jul 2020, at 9:49 pm, F@ <f at donghi.co.uk> wrote:
>> Hi,
>> I should have posted a better screen shot. My installed plugins list is
>> the same as the All plugins list.
>> <Screen Shot 2020-07-20 at 12.45.33.png>
>> Hence my question about missing plugins.
>> Warm regards,
>> Frank
>> On 17 Jul 2020, at 15:53, Nicolas Cadieux <njacadieux.gitlab at gmail.com>
>> wrote:
>> Hi,
>> You are looking at the installed plugins only. Click on All and you
>> should see your plugin in the lists, if it’s experimental, it will only
>> show up if you apply the proper settings in the setting tab.
>> Nicolas Cadieux
>> Ça va bien aller!
>> Le 17 juill. 2020 à 10:17, F@ <f at donghi.co.uk> a écrit :
>> Hi list,
>> This is new to me so apologies if something not complete.
>> I am on a iMac late 2013 running MacOS Sierra 10.12.6
>> I have the standard stable QGIS install 3.8.1 (full info below)
>> I wish to upload a map to qgiscloud or package it so that another user
>> can download the map.
>> For some reason I am missing the python plugins.
>> <Screen Shot 2020-07-17 at 15.08.41.png>
>> Any help/guidance very welcome.
>> I have looked into installing an older copy of QGIS for the macOS, but
>> worried I will lose all my work.
>> Warm regards,
>> Frank
>> Full QGIs info:
>> QGIS version
>> 3.8.1-Zanzibar
>> QGIS code revision
>> dcd95cc648 <https://github.com/qgis/QGIS/commit/dcd95cc648>
>> Compiled against Qt
>> 5.12.3
>> Running against Qt
>> 5.12.3
>> Compiled against GDAL/OGR
>> 2.4.1
>> Running against GDAL/OGR
>> 2.4.1
>> Compiled against GEOS
>> 3.7.2-CAPI-1.11.2
>> Running against GEOS
>> 3.7.2-CAPI-1.11.2 b55d2125
>> PostgreSQL Client Version
>> 11.3
>> SpatiaLite Version
>> 4.3.0a
>> QWT Version
>> 6.1.4
>> QScintilla2 Version
>> 2.11.1
>> Compiled against PROJ
>> 5.2.0
>> Running against PROJ
>> Rel. 5.2.0, September 15th, 2018
>> OS Version
>> macOS Sierra (10.12)
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200721/b6ddbb9b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200721/b6ddbb9b/attachment-0001.png>
