[Qgis-user] How to install QGIS in Debian 11?
Patrick Dunford
enzedrailmaps at gmail.com
Fri Jul 24 09:10:43 PDT 2020
I would think Flatpak themselves are more likely to have documentation
about limitations. You might also try the Qgis flatpak project on Github
for assistance.
On 24/07/20 1:26 am, Todd Pfaff wrote:
> On Wed, 22 Jul 2020, Richard Duivenvoorde wrote:
>> - learn about 'flatpak' and use that to run 3.14
>> (https://qgis.org/en/site/forusers/alldownloads.html#flatpak). Though
>> flatpak has some limitations as it runs in a sandbox...
> Are those limitations and how they impact the capabilities of QGIS
> documented anywhere? I don't see anything about limitations here:
> https://www.qgis.org/en/site/forusers/alldownloads.html#flatpak
> nor here:
> https://flathub.org/apps/details/org.qgis.qgis
> I believe I've run into a big limitation. I've installed flatpak QGIS
> on a CentOS 7 linux system. When I try to run it I get this error:
> $ flatpak run org.qgis.qgis
> QGIS starting in non-interactive mode not supported.
> You are seeing this message most likely because you have no DISPLAY
> environment variable set.
> Any ideas about what limitation is causing that error?
> Thanks!
> Qgis-user mailing list
