[Qgis-user] Python to export layouts
Paul Wittle paul.wittle at dorsetcouncil.gov.uk
Wed Jul 29 10:35:22 PDT 2020
I've found the python code to export a layout from a QGIS project directly from the command line which is great but the database overlays are missing from the resulting PDF.
The layers use the authentication manager so I suspect it is something to do with initialising the password manager correctly but the example I've found so far is for an older version. Is anyone able to point me at an example that uses overlays from a database?
This is what I have so far:
#!/usr/bin/env python3
import os, time
from qgis.core import (QgsProject, QgsLayoutExporter, QgsApplication, QgsAuthManager)
QgsApplication.setPrefixPath("/usr", True)
gui_flag = False
app = QgsApplication([], gui_flag)
app.initQgis()
project_path = os.getcwd() + '/project.qgs'
project_instance = QgsProject.instance()
project_instance.setFileName(project_path)
project_instance.read()
authMgr = QgsApplication.authManager()
if authMgr.authenticationDatabasePath():
   # already initilised => we are inside a QGIS app.
   msg = 'Inside QGIS'
else:
   # outside qgis, e.g. in a testing environment => setup env var before
   # db init
   os.environ['QGIS_AUTH_DB_DIR_PATH'] = "Path/qgis-auth.db"
   msg = 'Master password could not be set'
   assert authMgr.setMasterPassword("password", True), msg
   authMgr.init( " Path /qgis-auth.db" )
manager = QgsProject.instance().layoutManager()
timestr = time.strftime("%Y%m%d-%H%M%S")
layout = manager.layoutByName("layout ") # name of the layout
# or layout = manager.layouts()[0] # first layout
exporter = QgsLayoutExporter(layout)
exporter.exportToPdf(project_instance.absolutePath() + "/layout-" + timestr + ".pdf",
                     QgsLayoutExporter.PdfExportSettings())
app.exitQgis()
Thanks,
Paul Wittle
[cid:image001.jpg at 01D665D7.034B7860]<https://www.dorsetcouncil.gov.uk/>
Business Solutions Analyst (GIS)
ICT Operations
Dorset Council
01305 228473 <tel:01305%20228473%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20>
dorsetcouncil.gov.uk<https://www.dorsetcouncil.gov.uk>
[cid:image002.png at 01D665D7.034B7860]<https://www.facebook.com/DorsetCouncilUK>
[cid:image003.png at 01D665D7.034B7860]<https://instagram.com/DorsetCouncilUK>
[cid:image004.png at 01D665D7.034B7860]<https://twitter.com/DorsetCouncilUK>
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/416433
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200729/e6e43e81/attachment.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200729/e6e43e81/attachment.jpg>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200729/e6e43e81/attachment.png>
Type: image/png
Desc: image003.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200729/e6e43e81/attachment-0001.png>
Type: image/png
Desc: image004.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200729/e6e43e81/attachment-0002.png>
