[Qgis-user] QGIS Authentication to an ArcGIS Enterprise Portal
Warren Medernach
wmedernach at gmail.com
Mon Jun 1 09:45:09 PDT 2020
Hi Myall, just checking in on this to see if you were able to put some
details together about the OAuth2 connection to Portal from QGIS. Even a
screen cap of working settings would be helpful.
Thanks!
Warren
On Tue., May 26, 2020, 6:06 p.m. Warren Medernach, <wmedernach at gmail.com>
wrote:
> That would be fantastic, thank you!
> Please keep me posted.
> Warren
> On Tue, May 26, 2020 at 4:54 PM Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
>> On Wed, 27 May 2020 at 09:35, Warren Medernach <wmedernach at gmail.com>
>> wrote:
>> > Thanks so much for the response Nyall, at least now we know something
>> should be possible.
>> > Is there anyway you could share a screen cap, or provide some guidance
>> for the required settings in the OAuth2 dialog in QGIS.
>> Let me see if I can find time to write this up as a blog post later
>> today... there's a bit involved in the setup which I'd like to step
>> through
>> Nyall
>> > Thanks again,
>> > Warren
>> > On Tue, May 26, 2020 at 4:42 PM Nyall Dawson <nyall.dawson at gmail.com>
>> wrote:
>> >> On Tue, 26 May 2020 at 03:59, Warren Medernach <wmedernach at gmail.com>
>> wrote:
>> >> > QGIS version: 3.12.2-București
>> >> > ESRI Portal version: 10.7.1
>> >> > We have recently been testing out the access to our ESRI Enterprise
>> Portal from QGIS using the ArcGisMapServer and ArcGisFeatureServer
>> connectors. Our Portal is configured via SAML for Enterprise Logins using
>> our corporate domain credentials as well as Built-In ArcGIS Portal users.
>> >> > We have tried the following Authentication methods: Basic
>> Authentication using a built-in Portal user and Token based Authentication.
>> >> > It doesn't seem to matter which auth method we use, QGIS will only
>> see content that is shared with Everyone in the Portal.
>> >> > Is it possible to connect to an ESRI Portal and have QGIS only show
>> content the user has access to based on their settings in the ESRI Portal?
>> ie. the Groups and Content they have access to.
>> >> I've had great experience using the o2 authentication setup and ESRI
>> >> Portal. In recent QGIS releases this is seamless and should exactly
>> >> match your needs.
>> >> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200601/c154668d/attachment.html>
