[Qgis-user] How to calculate surface volume from UAV DEM tif files in QGIS
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Mon Jun 8 08:58:18 PDT 2020
I imagine you are looking for the area? You can make a polygon and measure the area of a shape. https://gis.stackexchange.com/questions/23355/calculating-polygon-areas-in-qgis
You can also use the distance measure tool in the toolbar and use the area option.
Nicolas Cadieux
Ça va bien aller!
> Le 8 juin 2020 à 11:13, Sean Hill <seanhillsa at gmail.com> a écrit :
> Is it possible to calculate surface volume from aerial photographs (orthomosaic maps in DEM tif file format) in QGIS?
> Everything I have found on the internet refers to using
> satellite images. I did find one article on generating surface
> volume from drone imagery but is difficult to understand as it is
> missing some steps and/or the steps aren't clear and do not render the
> same results from step to step even though I follow the steps to the letter.
> Please help
> Sean
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200608/d233eeed/attachment.html>
