[Qgis-user] shapefiles
forestermcgannon
forestermcgannon at gmail.com
Mon Jun 15 22:55:11 PDT 2020
when I "uncheck" the ortho layer, the property boundary (the shapefile) appears. When I display the ortho imagery again, no boundary. It is like the shapefile is "under" the ortho image, when I of course want it to show "on" the ortho image. most seems like a vector display issue to me.What do you think?ThanksJimJim McGannonForestry Landscape Consultant, LLCColoradotreearborist.comĀ 303-526-1118
-------- Original message --------From: Raymond Nijssen <r.nijssen at terglobo.nl> Date: 6/15/20 11:35 PM (GMT-07:00) To: qgis-user at lists.osgeo.org Subject: Re: [Qgis-user] shapefiles Hi Jim,That sounds a lot like a projection issue.Are your layers completely misaligned, like not overlapping at all? Or are they overlapping but with just a few (hundred) meters shift?An easy trick is adding the world layer and see which of your layers appears at the expected spot. You can do this by typing "world" in the coordinate bar beneath the map.Good luck!RaymondOn 16-06-2020 05:24, forestermcgannon wrote:> Why is my shapefile that I imported into project, not showing up with my > orthoimage. The shapefile is a property line boundary.> Thanks> Jim> > > > _______________________________________________> Qgis-user mailing list> Qgis-user at lists.osgeo.org> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user> _______________________________________________Qgis-user mailing listQgis-user at lists.osgeo.orgList info: https://lists.osgeo.org/mailman/listinfo/qgis-userUnsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200615/402e3264/attachment.html>
